185 Crank gear R&R?
Wes(Va) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Topic: 185 Crank gear R&R?
    Posted: 15 May 2025 at 1:23pm
Does the cank have to come out to replace gear?  Oil pump bolts backed out and gear is worn down...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 5:24pm
With the camshaft removed and the idler gear removed, there may be a way to get a bearing splitter around the crank gear with proper pulling equipment. Get it under pressure and quickly heat the gear (staying away from the crank as much as possible) and using an impact wrench to quickly pull it off while it is hot.  This can't be done half-arssed. You will have to have good equipment and be set-up to pull it quickly. This is certainly NOT a normal occurrence.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 15 May 2025 at 10:49pm
leave it to me to do something thats unusual..   I bet getting a new gear pressed on while in the engine would be somewhat of a feat as well.  I see agco still has a price beside the gear on partsbooks!  I'll call tomorrow and see if they can actually get one.  I may end up pulling engine, and lay it on its side.  Then pull the crank out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 6:02am
In all these decades I have never had an oil pump work the mounting bolts loose. Replacing a crank gear is just something that never happens.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 4:50pm
“ I bet getting a new gear pressed on while in the engine would be somewhat of a feat as well. ”
Shouldn’t be. Heat the gear and freeze the crank as much as possible. Should go right on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2025 at 4:53pm
Drop the gear into a deep vat fryer for an hour and quickly grab it with a channel locks and have a prepared piece of pipe as a driver and pound it on. It will not go hard but you have to be fully prepared. I would consider removing the front main cap and the upper bearing shell to keep them away from the heat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes(Va) Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 32 minutes ago at 1:03pm
I was thinking to pull all caps and inspect.  My brother was moving it around the barn, when he heard the noise and saw the oil light on and cut it off quickly.  I dont think there will be much damage but we'll see.  I overhauled this engine about 5 or 6 years ago, and I think I'll use some loctite on the pump bolts this time.  Got a used crank gear and oil pump gear on the way from Wellert's- he said these gears came out of one that the ear snapped off the pump!  Also have the radiator out and at the radiator shop as the top tank seam came apart..  just things that should've been done over the winter!
