185 brakes |
Gatz in NE
Joined: 11 Sep 2009 Location: Lincoln, NE Points: 1064 |
Topic: 185 brakesPosted: 26 Jul 2025 at 1:56pm |
white lithium on the linkages if you got some; otherwise some heavy lube , Red & Tacky is a good one.
Nothing on the balls or tracks…lube of any kind will attract and keep dirt & grit which will eventually “ gum up the works “ which can lead to unexpected lock-up. Note that it is important to have the gap set correctly between the brake disc(s) and the housing per the manual. Edited by Gatz in NE - 26 Jul 2025 at 2:01pm |
automaticdave
Joined: 20 Jan 2011 Location: Granton, ON Points: 261 |
Posted: 26 Jul 2025 at 1:36pm |
Need to replace the brakes on the 185, what kind of lube can one use mainly on the band linkages and on the balls or should I just kleen and free all parts and don't bother with any lube? Thanks Dave
