185 5 Rail rims
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Topic: 185 5 Rail rims
    Posted: 28 Oct 2023 at 9:54pm
I know how to shift 4 rail rims by loosening the eccentrics but my question is how do I shift my 5 rail rims? Do I just remove the rim rail stops and shift or is there more to it? TIA.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2023 at 10:10pm
Remove rail stops and then loosen all five big nuts to flush or half-way off the end of their bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 12:52pm
Thanks Dr. Do I have to jack it up or can I shift them on gravel?
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 1:05pm
Designed to get shifted with weight on them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 1:27pm
Thanks again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 5:33pm
Id think it would work better with weight on them
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2023 at 5:52pm
Lock other wheel brake and spin it desired direction. Put lock in position you want it to stop at then assemble opposite lock to rail BEFORE tightening nuts back up. Tighten them evenly from bottom up. I wouldn't go more than a turn at a time. Works on 8000's. Type of surface doesn't matter.
