185 3 point won't lower while running |
tnac ![]() Bronze Level ![]() Joined: 11 Sep 2009 Location: Tennessee Points: 130 |
![]() ![]() ![]() ![]() ![]() Posted: 17 Jul 2021 at 4:14pm |
I have a 185 that the 3 point will not lower while running. If off it will lower but raises immediately when started. Any suggestion?
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 966 |
You have a hydraulic spool stuck or linkage ( ussually draft control ) that is binding and letting the spool return to center. Soak all linkages with penetrant that are in under the plate connecting to all 4 or 5 levers. They must all move.
Try moving the 2 levers setting behind the 3 pt and remote cylinder controls. Move too far back and then forward a few times. Start tractor and see if it operates. There's older posts on here from people that explained it a lot better.
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Traction booster/position linkage is froze up most likely.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22063 |
Just fixed a One-Seventy today by loosening the pivot bolt the TBoost finger pivots on. Let the bolt be the pivot and quit worrying about the bushing inside of the finger.
