180D starter gave it up |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35282 |
Topic: 180D starter gave it upPosted: 30 Jan 2026 at 3:33am |
Several years back the Starter on my 180 decided time to quit so bought a AGCo replacement thru a known supplier, that Lucas style lasted a couple of years but as my old engine is tired and cranks pretty long to start it gave up just at two years and out of warranty. So fleabay had a New Lucas style really cheap and I bit, well it gave it up after I had finished blading off driveway cleaned the snow off blade and went to restart to put back in shop. Managed to get it cranking put back inside and pulled starter. Took it to an old friend that rebuilt starters long ago does no longer and we tested it. First comment as we took it apart: “Chinese” or Some Asian junk. Side windings were iffy and likely the lacquering on those was failing or improperly applied, then he growled the armature, sure enough it was ‘Soft Shorted’. “Junk”. Having had two of these fail opted to order a Agparts Denso, gear reduction unit. Know is Korean, should be here today, hope to have back running by next round of Pretty.
PaulSamwel
Posted: 30 Jan 2026 at 1:29pm |
Let us know how that new starter works out.Just bought a Lucas style from DB Electric for my 185.Supposed to be a higher quality rebuild..we'll see.
Thanks(1)
Posted: 30 Jan 2026 at 1:33pm |
In our family, we've gotten three gear-reduction starters from DB electric for the same A-C engine family application and have had no regrets.
Edited by DrAllis - 30 Jan 2026 at 1:34pm |
DMiller
Posted: 30 Jan 2026 at 2:06pm |
Aided another 185 owner near us install one of these, lighter, spins faster, should be good just not the Old AC but that is disappearing.
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 140 |
Posted: 30 Jan 2026 at 2:30pm |
I have two starters that occasionally have the drive not grab, so I have a gear reduction starter from DB on the shelf. Nice to hear that others have had good results.
Ted |
DMiller
Posted: 02 Feb 2026 at 12:19pm |
Had the old one off, New One was on in Minutes!! Not ever had that easy a install. Tractor cranked like not ever before started just fine so shut down and gathered everything up cleaned up, and tried to put outside to do some snow cleanup, won't crank, ammeter goes hard Neg past 60a, checked engine still turn by hand at fan so tried again, got to roll once then starter locked back up.
All States Ag getting a return slip sent out, shipping another. Figures too easy, HAD to go south.
Ky.Allis
Joined: 31 Jan 2010 Location: Kentucky Points: 1044 |
Thanks(1)
Posted: 02 Feb 2026 at 1:37pm |
WOW! that sounds like my kind of luck. I always said that if you cut a woman in half, I'd get the half that eats.
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12066 |
Posted: 03 Feb 2026 at 7:46am |
Dave, Make sure your Battery cable is heavy enough. In your pic, the cable doesn't look like it's that heavy. Also, make sure the block has at least two heavy ground cables going from the block to frame rail. One on each side. The Starter may be searchin' for a ground. The reason why its rolling over slow. First, it Started right up, then it rolled over slow. Sounds like a ground issue to me or not enough current to the Starter. One or the other or both! HTH Steve@B&B
deckape
Joined: 01 Nov 2023 Location: florida / Alaba Points: 18 |
Posted: 03 Feb 2026 at 7:55am |
It's alway the groud ! Check that connection at the eyelet , looks iffy .
Les Kerf
Posted: 03 Feb 2026 at 11:13am |
Hmmm... In normal operation the solenoid is the only part of the circuit that draws current through the ammeter, the main starter motor circuit being outside of the meter. The massive amp reading indicates that the starter is indeed trying to pull current through the solenoid circuit, and the wiring is obviously not heavy enough to make it work that way (it isn't supposed to). I am not familiar with this particular starter, but some of the new gear reduction units require a separate ground wire from the battery to a discrete lug on the starter itself because of the way it is designed; the traditional method of grounding through the chassis will not work if that is the case with this starter. The gear reduction starter we put on my Son-in-law's HD5G was like that, it didn't work properly until I read the instructions (who would do a thing like that?) and wired it correctly
DMiller
Posted: Yesterday at 6:20am |
Same Wiring the Lucas Had since built. These starters draw less current than the OEM design do. As to cranking Slow, it didn't, cranked faster than anytime I have ever started the old Gal. Really shocked me as it did turn over so fast.
My Ammeter always went hard Neg during Cranking, just was cranking. This time Starter was Locked Tight.
Les Kerf
Posted: Yesterday at 8:41am |
" ammeter goes hard Neg past 60a" Apparently that is normal for a Lucas starter solenoid to draw massive amounts of current? ![]() ![]() Edited by Les Kerf - Yesterday at 8:46am |
DMiller
Posted: Yesterday at 8:52am |
Not ever had any different reading on this tractor, always started. And DID start once on New Starter.
PaulSamwel
Posted: 21 hours 55 minutes ago at 12:27pm |
Sounds like you need to pull starter and bench test if power and ground checks out.
PaulSamwel
Posted: 21 hours 50 minutes ago at 12:32pm |
I just put a DB electric Lucas starter on my 185 and bendix will ocassionally not fully engage ring gear or just partially engage.Cringe when that happens ,might need to get a gear reduction starter.
DMiller
Posted: 20 hours 29 minutes ago at 1:53pm |
Bad new starter on way back to Ag Parts, next new one arrived Noon and On, NOTHING changed as to Install, has 15-20 amp draw during Cranking starts like not ever started prior, spins up Sweet and so far started let batteries recharge got back to low A input shut down and repeated three times. Just got a bad one first go round.
Les Kerf
Posted: 19 hours 33 minutes ago at 2:49pm |
Nice! Glad it is fixed ![]() 15-20 amps to run the solenoid is more realistic. Any time I see an ammeter being pegged HARD it raises a red flag as there is definitely something wrong.
DMiller
Posted: 19 hours 20 minutes ago at 3:02pm |
Motor was locked. Solenoid on starter sees hard battery power to motor. Ammeter sees what is moving across the line as high draw sucks from every circuit fed by Batteries. Two group 31 12volt.
Alternator feed is across starter hot post so will see system draw or feed. |
Les Kerf
Thanks(1)
Posted: 15 hours 2 minutes ago at 7:20pm |
I must have misunderstood the above quoted statement ![]() I interpreted it to mean that the original starter had always caused the ammeter to peg hard Negative.
DMiller
Posted: 5 hours 16 minutes ago at 5:06am |
Not really ever pegged But as it did not raise eyebrow as always started only noted was always higher than halfway to 60A Neg. When the Lucas unit quit would only show a twitch Neg.
Les Kerf
Thanks(1)
Posted: 2 hours 33 minutes ago at 7:49am |
Ah, my mistake then
