180D starter gave it up |
DMiller
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35233 |
Topic: 180D starter gave it upPosted: 19 hours 32 minutes ago at 3:33am |
Several years back the Starter on my 180 decided time to quit so bought a AGCo replacement thru a known supplier, that Lucas style lasted a couple of years but as my old engine is tired and cranks pretty long to start it gave up just at two years and out of warranty. So fleabay had a New Lucas style really cheap and I bit, well it gave it up after I had finished blading off driveway cleaned the snow off blade and went to restart to put back in shop. Managed to get it cranking put back inside and pulled starter. Took it to an old friend that rebuilt starters long ago does no longer and we tested it. First comment as we took it apart: “Chinese” or Some Asian junk. Side windings were iffy and likely the lacquering on those was failing or improperly applied, then he growled the armature, sure enough it was ‘Soft Shorted’. “Junk”. Having had two of these fail opted to order a Agparts Denso, gear reduction unit. Know is Korean, should be here today, hope to have back running by next round of Pretty.
PaulSamwel
Posted: 9 hours 36 minutes ago at 1:29pm |
Let us know how that new starter works out.Just bought a Lucas style from DB Electric for my 185.Supposed to be a higher quality rebuild..we'll see.
Thanks(1)
Posted: 9 hours 32 minutes ago at 1:33pm |
In our family, we've gotten three gear-reduction starters from DB electric for the same A-C engine family application and have had no regrets.
Edited by DrAllis - 9 hours 31 minutes ago at 1:34pm |
DMiller
Posted: 8 hours 59 minutes ago at 2:06pm |
Aided another 185 owner near us install one of these, lighter, spins faster, should be good just not the Old AC but that is disappearing.
TedN
Joined: 30 Apr 2025 Location: Central WA Points: 138 |
Posted: 8 hours 35 minutes ago at 2:30pm |
I have two starters that occasionally have the drive not grab, so I have a gear reduction starter from DB on the shelf. Nice to hear that others have had good results.
Ted |
