180D starter gave it up
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Topic: 180D starter gave it up
    Posted: 2 hours 5 minutes ago at 3:33am
Several years back the Starter on my 180 decided time to quit so bought a AGCo replacement thru a known supplier, that Lucas style lasted a couple of years but as my old engine is tired and cranks pretty long to start it gave up just at two years and out of warranty. So fleabay had a New Lucas style really cheap and I bit, well it gave it up after I had finished blading off driveway cleaned the snow off blade and went to restart to put back in shop. Managed to get it cranking put back inside and pulled starter. Took it to an old friend that rebuilt starters long ago does no longer and we tested it. First comment as we took it apart: “Chinese” or Some Asian junk. Side windings were iffy and likely the lacquering on those was failing or improperly applied, then he growled the armature, sure enough it was ‘Soft Shorted’.   “Junk”. Having had two of these fail opted to order a Agparts Denso, gear reduction unit. Know is Korean, should be here today, hope to have back running by next round of Pretty.
