180
SHAMELESS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Topic: 180
    Posted: 05 Jul 2010 at 4:37pm
kept losing power on my 180 D, put new fuel filter on, ran great for about 10 mins, then lost power again, took settling bowl and screen off, wasn't very dirty, cleaned it, turned fuel on under tank while bowl off, just a drip!. is there a raised pipe inside the tank where the fuel exits? or is it just the threads from the settement bowl holder? i guess what i'm trying to say is the hole in the tank a flush hole with threads? i'm gonna hate to take the tank off as i just filled it!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 4:52pm
You probable have a bug blocking the fuel flow.  I've had that happen a few times.
Leonard View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leonard Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 5:40pm
Shameless, try blowing some compressed air back up the fuel tube at the bottom of the tank and see if the flow improves.  Make sure to either remove or loosen the fuel cap.  This will let you know if there is something in the tank that shouldn't be there, at least.
Leonard
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 5:44pm
Best thing to do is to thread the valve and bowl top (working on memory here, it has been a few years since I had a 180) out of the tank.  Let some fuel flow out if it will at full stream.  If it comes full stream then clean out the valve you removed and put it back in.  This can be messy but it usually prevents the repeat problem.  It is best to put you finger over the hole after it flows full while you clean the valve with some air or what ever you may have handy.
SIMPLICITY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SIMPLICITY Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2010 at 8:34pm
HELLO
    GO TO THE TOP OF YOUR INJECTOR PUMP AND REMOVE THE RETURN LINE FITTING, START THE TRACTOR IF IT DOESN'T SHUT DOWN THEN SCREW  THE BARB FITTING BACK ON TOP OF THE PUMP. IF THE TRACTOR SHUTS DOWN THEN THE BARB FITTING IS STOPPED UP. THERE IS A RUBBER CAM RING IN THE PUMP FALLING APART MOVING TO THE TOP OF THE PUMP AND PLUGGING THE FITTING HYDRO LOCKING THE PUMP.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2010 at 2:28am
thanks guys!, i took the sediment bowl off, turned the fuel back on and it's just a slow drip from the tank with the cap off....so it must be plgged there, taking the tank off to clean it, will siphon the tank out then pull off, the skeeters got to bad outside tonight after another rain so i quit, but should be running tomarrow. thanks again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 2:46am
found the problem! tractor was sabotoged...took the tank off after siphoning 15 gals of fuel out the top, that fuel was good and clean, lifted the tank off, drained out the remaining into a bucket, took a flashlight and shined down inside, saw something, couldn't tell what it was at first...got it towards the fill cap and pulled it out with a long needle nose pliers....it was a very expanded tampon! i think i got most of it out! gonna take it into the car wash and spray it out tomarrow, make sure there's not any gunk in there as long as i have it off the tractor. i may change the planter to the 7010 to finish, maybe while the tank is off i'll wash out around the cowling and body, maybe find the wires that were on fire a couple years ago when i lost all lights! pffft!
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 2:53am
Now I have heard everything.
You may want to spray it with some Summer's Eve feminine hygiene spray.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote SHAMELESS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2010 at 11:39am
thanks clay!!!! lol
