180 temp gauge not working |
farmer_rob ![]() Silver Level ![]() ![]() Joined: 11 Sep 2009 Location: N.Lancaster ont Points: 362 |
![]() ![]() ![]() ![]() ![]() Posted: 02 Sep 2024 at 9:41pm |
Like the title says my isn’t working. I have checked the continuity of the sending wire so my question is do i replace the sending unit or guage .
Thanks |
if farming was easy everybody would be doing it
Jim.ME ![]() Orange Level ![]() Joined: 19 Nov 2016 Location: Maine Points: 962 |
It is hard to say which needs replacing until you do some checking. Does the gauge move at all or is it stuck one way or the other? What happens at the gauge if you remove the wire from the sender and ground the wire? As for replacing one or the other. The ohm range for both a gauge and sender must match. I don't have a 180's service manual to check, your service manual may give the ohm range for them, which you will need if you want to get a replacement (other than by part number from AGCO). If using aftermarket replacements, I find it as easy to get a matching gauge and sender together in a kit.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8334 |
Theres a way to easliy test them - cant remember how tho- ground it out,,
8070nc ![]() Orange Level Access ![]() Joined: 21 Mar 2019 Location: North Carolina Points: 603 |
I think this right. I might have it backwards. If the guage is ok and you take the wire off the sensor it should go full hot. If you ground the wire it should go full cold
1984 80780
1957 D14 DES 300 with 25000 engine 616 tractor |
Heds43 ![]() Bronze Level ![]() ![]() Joined: 03 Sep 2024 Location: Cleveland Oh Points: 6 |
Ok
ac-mike ![]() Silver Level ![]() Joined: 14 Sep 2009 Location: Kentucky Points: 276 |
On 180 and 185 models I have had problems with air being trapped at the thermostat not allowing water to get to the sending unit. This can also cause the tractor to overheat. Look in radiator to see if water is circulating and feel thermostat housing to see if temperature is same both sides of thermostat. The cure for this is to loosen thermostat housing allowing water to take the place of the air trapped inside. The best cure for this problem is to be sure the thermostat has a small hole to relieve trapped air. I had enough problems with this that I always drill a small hole in thermostat.
D-12III, 200D, 170G, HD-3, D19D 3pt, D17D High Crop, WD45G p/s, D15IID, D15IIG, D15G IND, 655, (3)WD45D p/s, 700, 816
Well this morning I unhooked the wire at the sender then grounded that wire and noticed the guage going full hot.
So with that happening I’m thinking I need a new sender. Am I correct? Thanks in advance |
Leon n/c AR. ![]() Bronze Level ![]() ![]() Joined: 19 Mar 2013 Location: Heber Springs A Points: 175 |
Sounds like you need a new sensor . Leon
Thats what I would do
1984 80780
Anyone have the part for that sending unit?
KJCHRIS ![]() Orange Level ![]() ![]() Joined: 21 Dec 2015 Location: WC Iowa Points: 954 |
Sender #241249.
IF your gauge says Allis Chalmers on its face try this OEM number for AC185 & 200 tractors. The AGCO dealer will need to update the number to AGCO.
IF your gauge is an aftermarket this sender number may not work with it. I've not seen any 180's that had electric temp gauge, they've had the old tube & bulb type gauges. The 185 & 200 usually have electric gauge. |
Don Jr NY ![]() Silver Level ![]() Joined: 11 Sep 2009 Location: Waterloo NY Points: 358 |
To my knowledge the bulb and tube style gauges ended with the D series tractors. All 100 series tractors have the electric gauges. I have 13 of them ranging from the 170 to the 220 and they are all factory original wiring with electric gauges.
