180 Roosa Master Injector Pump ? |
nsula_country ![]() Orange Level ![]() ![]() Joined: 10 Mar 2011 Location: NW Louisiana Points: 218 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Apr 2011 at 11:16pm |
My 180 has a Roosa Master injector pump. It is leaking diesel when you pull the fuel cut-off cable out to start. It is leaking around the bell crank shaft that goes into the pump for the fuel cut-off. I know it is a seal or o-ring has failed. My question is can I service the seal on the tractor or should I take it to a diesel service shop and have it gone through? It doesn't have a safety wire on any bolt and I have only had it a few months. It also seems to change RPM's without moving the throttle lever (mostly runs up like it wants to runaway). Is the governor inside the pump or external? It is also hard to start (fair weather, no heat or ether). Cold be low compression, unknown hours. Could need reworked? Opinions? Thanks! CT |
Orange Blood ![]() Orange Level ![]() ![]() Joined: 29 Nov 2010 Location: ColoradoSprings Points: 4053 |
Servicing the pump on the tractor is doable depending on which dirrection the shaft is on, I don't own a 180, so not sure if they are the same as the 190. HOWEVER, you can get yourself in a world of hurt if you get any dirt whatsoever in the pump. It really is not a good idea. If the govenor is surging, you could have a couple of different pump problems, I think the best idea would be to take it to a pump shop and have it rebuilt.
Since the tractor is new to you, I would do a compression check just to see where things are at, that way you know, but starting issues could be pump related or not.
Edited by Orange Blood - 21 Apr 2011 at 6:14am |
Still in use:
Throttle and shutoff shaft can both removed without removing pump. Remove top cover there is a clip holding the two shafts togather. Remove the clip and slide the shafts out. Remove the screw holding arm on throttle shaft and it can be removed. Make sure the clip is installed with long leg to back of pump. MACK
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5102 |
as mack says the leak can be stopped with throttle and shutoff shaft orings. your problem sounds more serious than just leaky orings though. Odds are the flex ring is broken apart inside the pump, plugging the return causing housing pressure to increase, causing the leak, as well as the erratic governing. It is in need of professional attention. good luck, Ed.
I figured it was more than a fuel leak. It only leaks when you pull the fuel cable out to the run position. The governor issue is you can set the speed and it will increase in RPM while under a load. Sometimes it will come back down other times you have to bump the throttle down a bit. I'm afraid it may try to "run away" on me and overspeed.
This is my 1st Allis Chalmers, I have always wanted one. I did not know what to look for. I got a good deal, but between the injector pump (hope injectors are ok) and the power director slipping, I may have a basket case that will cost me more than I thought. Hopefully it will be worth while once I get it all repaired and painted. CT
sandylakeimplement ![]() Orange Level ![]() ![]() Joined: 18 Sep 2009 Location: Sandy Lake, PA Points: 399 |
We just did a pump reconditioning yesterday for a 180. $680 including about $130 for items not always needed. Bill
Sandy Lake Implement
Sandy Lake, PA 724-376-2489 www.sandylakeimp.com FIND US ON FACEBOOK |
Injector pumps are never cheap to O/H, but its nature of the beast. I still prefer dealing with one injector pump and injectors vs plugs, wires, cap, rotor, condenser, mag (if it has one) ect. Not to mention carburetor and then timing/adjusting everything into harmony.
I'm convinced it will be better to have it serviced and gone through. If I don't now, I will have to do it in the future with hay in the field with rain threatening.
Thanks, |
DB pumps run right around $500 - $600 depending on how bad of shape it's in.
