180 rear main oil seal |
Doyle B(NY) ![]() Silver Level ![]() ![]() Joined: 20 May 2011 Location: New York Points: 150 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Nov 2011 at 5:39am |
How bigg of a job is it to replace the rear oil seal we hav e been putting it off for years and seens its starting to leak worse might be time to fix it.
thanks
Split at rear of engine, remove flywheel, pry old seal out, drive new seal in. Always replace wear ring on flywheed. Put some oil on new seal and wear ring and reassemble. MACK
PS put a small amount of loctite on wear ring before driveing on flywheel.
Ok thank you very much
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8357 |
Wait a minute !!!! Make sure to get the new RUBBER ORINGS that go in the groves on the adapter plate , big one and little one - those are the problem most of the time !!!!
If the orings are leaking, the leak will be on front of adapter plate. MACK
