180 questions
thendrix View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Topic: 180 questions
    Posted: 16 Oct 2026 at 9:22pm
There's a 180 for sale about a hour or so from here and I'm looking for a backup for my Kubota M6800. According to tractor data, the 180 is quite a bit heavier than my Kubota which would be a good thing. Only issues I can see are the exhaust height and the low gear speed. According to tractor data the exhaust height is 90". Is this right? That would put the exhaust at 7 1/2 feet? I know I can cut the pipe. Just seems mighty tall for a 70 hp tractor. Also is the 2.1 mph in 1st gear correct? My Kubota with 28" rears runs about 1.6(?) I think and can run out of power with a windrower in heavy litter. Think of a windrower as a 6 1/2 ft tiller 6 inches deep in heavy soil. Even if it's not the best option or just flat won't work I'll still call about the tractor. Any quirks other than the normal gear jumping?
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 5:34am
I have spent a lot of hours on a 180 and 185. I don't think you will find low gear too fast for any job.
Dad's 185 had 30" tires and the 180 had 28". The 185 was a bit faster, but still not too fast.
whatscooking View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote whatscooking Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 5:46am
What ya intend to use it for, what other kind of implements can you hook onto? When we finally got a 180 on the farm it got used for everything from pulling a 4 bottom plow through tough soil, pulling a 6 row no till Planter to square bailing. I dont think a windrower will bother it, but I'd have never pulled one ither.
Edited by whatscooking - 17 Oct 2026 at 6:01am
68 D21 81 7060
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 7:18am
It'll mainly be used for litter work in my chicken houses. That's the reason for the height concern. About the only other things I do with a tractor around here are maybe a rotary mower and if we decide to cut a little hay for our goats it'll get mower and baler duty. I haven't seen the tractor but the guy is asking $4k. $4k for a 70hp tractor, even one this old, I'm not expecting a whole lot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 7:45am
https://youtu.be/kBlj5yxzO0E?si=q8B1MwQQ57qPp6y2
He's a video we made about windrowing that explains it a little
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 7:45am
Modern tractors are lighter per HP than something from the 1960's. That Kubota weighs 5,000 lbs dry/no cab and a 180 is 6700 lbs dry/no cab.  Muffler stack height a problem?? Well, that can easily be dealt with.
Edited by DrAllis - 17 Oct 2026 at 8:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 9:06am
Well.... He sold it already. Guess I'll need to be quicker on the draw next time. Thanks anyway
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 4:40pm
thendrix, great informative video. Thanks for sharing. Looks like your Kubota & Predator make an efficient combo? It’s MFWD, shorter wheelbase, front loader, is probably very handy & somewhat better suited to the Predator 6.5’ width.
You mentioned that a 9’ wide Predator might benefit tractor wheel widths & bldg’s width? Maybe keep an eye out for another AC 180 or 185, especially if it could be matched to the larger 9’ wide Predator? Think it’s larger size & its AC 301 649 diesel should power it fine? Wondering if the 180/185s left wheels, if spaced all the way outside, might help straddle the Predator’s lefthand windrow making its 9’ swath more complete?
Anyway, maybe consider a trip to your local farm & fleet to pickup a pesticide respirator that has replaceable cartridges? It could provide you a better facial seal & filtration to minimize that nasty litter dust inhalation? Decades later, you’re lungs should be healthier & happier when you’re chasing after your grandkids… ;)
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2026 at 7:35pm
The motor is the 180 is a hoss for it's size and you can turn them up, I don't recommend it, but I know a guy down the road from me, with a turned up 180 with snap on duals pulling a 20ft disc and he says he has no problems, I figured he would tear out his rear end but he is still going.
Post Options Post Options   Thanks (0) Thanks(0)   Quote thendrix Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2026 at 2:13pm
I'll look into respirators again. The ones I've used before just weren't comfortable for the amount of time it takes to windrow 6 houses. A wider windrower would definitely help with enough hp to run it like I would want to. Typically the bigger the windrow the more it heats up which does more to kill bugs and bacteria. A 9 ft model would put the windrow far enough past the rear tire that the tractor wouldn't have to be up on the windrow to build the second side. The hp worry would be moving windrows together. Takes a lot of hp to move a windrow plus the litter that the windrow is on top of. Would be much easier with a very slow first gear/creeper gear.
This page was generated in 0.119 seconds.
