180 PTO ??
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Topic: 180 PTO ??
    Posted: 09 Mar 2012 at 1:28pm
On a 180 when you put the PTO in gear it pops back out if there is a load on it ie. bushhog but if there is no load on it it will stay in gear. whats wrong? thanks for any ideals. Tom
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 3:32pm
Tom - manual or hydraulic PTO engagement on your 180?  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 3:40pm
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 7:17pm
I bet there is an ear broke off the part inside the powerdirector housing on the linkage that slides the coupler to connect the shafts , go to Agco parts and check it out ; i had the same problem , that was the fix
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:15pm
Linkage is the start of the problem. Don't engauge all the way then wears the front end splines off of pto shaft.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 10:58pm
Thats also true what Mack said , check all the linkage , prolly wore some
Edited by DougG - 10 Mar 2012 at 6:20am
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 12:58am
Yeah mine did exactly what Mack Said.  Linkage gets worn, and the arm on the outside of the shaft can get a slight bend in it also.  I just lengthened the bottom linkage about 2 inches and works like a gem now.
