180 progress |
Post Reply |
rowcropmafia
Orange Level Joined: 11 Sep 2009 Location: illinois Points: 208 |
Posted: 08 Feb 2014 at 4:23pm |
DougG
Orange Level Joined: 20 Sep 2009 Location: Mo Points: 8091 |
Looking good! Luv the One Eightys!
rowcropmafia
DarrylinWA
Orange Level Joined: 12 Sep 2009 Location: Amarillo Texas Points: 1898 |
Looking good. Love the fab photos. Only thing I would suggest is to cap off the front wheel safety skid bars welded to the frame. When you wash it or get water in there, no place to go and in winter time could freeze. Other than that, keep up the great work Take care, Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
DougG
Very cute lil girl too ! Spend all the time you can with her , they grow up fast I kno ! Got a question about the AC engine , whats that coming out of the front of the injector pump drive gear plate ? A mechanical pump drive ? If so what pump do you use
Edited by DougG - 10 Feb 2014 at 2:59pm |
rowcropmafia
That was just the drain line for the turbocharger. On the cummins I have a mechanical pump on the front. It's an enderle 80 A pump
DougG
Gottcha , is it driven off the crank or a belt + pulley ?
rowcropmafia
I welded a drive hub to the vacuum pump gear and it is drivin off the front. That's why it has the aluminum front cover so its strong enough to hold the pump
rowcropmafia
rowcropmafia
Almost ready to go just have to get my fenders painted and finish up a few odds and ends
2wise4agm
Orange Level Joined: 19 Aug 2011 Location: Smithton, MO Points: 538 |
Will the 180 rear end and finals hold up to this much power? Or did you do something to them? Just curious
rowcropmafia
Everything behind the clutch is stock except the power director has been removed and the differential hss needle bearings. There are tractors out there making alot more power than this one with the same parts, but anytime you start putting alot of power to anything especially old parts you hope for the best and prepare for the worst
2wise4agm
Just wondering. I have kinda always wanted to do something like what you are doing to a 180. Just wasn't sure what else would be involved.
cracker jack
Bronze Level Joined: 06 Dec 2013 Location: Atwood TN 38220 Points: 5 |
What kind of exhaust manifold are you using. I am working on a similar project and I hope it comes out half as good as yours.
rowcropmafia
Mine is a custom header a local guy made. I'll get a pic for you or you could always use a stock manifold or some of the aftermarket stuff out there
Larry(OH)
Orange Level Joined: 11 Sep 2009 Location: Shreve Ohio Points: 1577 |
I like the Throttle handle!!!
'40 WC puller,'50 WD puller,'50 M puller '65 770 Ollie
*ALLIS EXPRESS contact* I can explain it to you, BUT I cannot understand it for you!! |
rowcropmafia
TeamAllis
Bronze Level Joined: 15 May 2013 Location: Bath NC Points: 43 |
How many cubes, what gear do you pull and what kind of hp do you think it will be making. Heard a lot about the Cummins.
rowcropmafia
It's just a 360 ci. Haven't had it on a dyno, I would guess 500 hp? I plan on pulling 7th maybe 8th gear if im lucky. We only run 3000 rpm so its really more about the low end torque. Haven't had it hooked to the sled with this motor yet so im guessing there is going to be a learning curve and alot of trial and error to get it to get it dialed in. Just playing around with it it feels like it has alot more power than my 301 did
Zaddison
Silver Level Joined: 19 Sep 2013 Location: Moweaqua il. Points: 174 |
What turbo, pump and injectors are you running to get 500 horse?
rowcropmafia
P pump. Borg warner s366 turbo
Bob C IL
Orange Level Joined: 25 Sep 2009 Location: Paris IL Points: 369 |
ROWCROP IM CALLIN YOU OUT ON THAT ALLIS... I'll bet you a roadsoda she runs awesome. Just don't tuck yur right leg behind yur left.....
rowcropmafia
We'll see how it runs in a couple of weeks. I am dying to get this thing hooked to a sled. I would gladly give up a cold beer for a nice pass down the track.
JayIN
Orange Level Joined: 18 Dec 2009 Location: SE/IN Points: 1982 |
Keep us posted!
Carl(NWWI)
Orange Level Joined: 13 Sep 2009 Location: NW WI Points: 950 |
What did you do to get 360 cubes?
mattb
Orange Level Joined: 11 Jan 2011 Points: 348 |
its a cummins 5.9
Carl(NWWI)
Oh that's right. I remember now.
Post Reply | |
