180 power director
Ohiosam View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohiosam Quote  Post ReplyReply Direct Link To This Post Topic: 180 power director
    Posted: 02 Oct 2023 at 6:42pm
A friend called, he was looking at a 180 at an auction. He started it but the power director lever was stuck in low and he could not get it to move. The tractor supposedly has sat a lot so I suspect a rusty linkage. Any other likely cause?
TIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 6:47pm
Lever needs to be used and oiled occasionally.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohiosam Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2023 at 6:56pm
Thanks Dr Allis.
I should clarify. The tractor would move, the lever would not.
Edited by Ohiosam - 02 Oct 2023 at 6:57pm
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2023 at 12:33pm
+1 to what the Dr. said. Same thing when I bought my 180. The rod with the detent notches slides inside  a tube and had seized up. Easy fix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 03 Oct 2023 at 6:16pm
Just bought a 185 with the same deal- theres a tube under the cowl hood with a spring and detent places- sprayed Blaster in there every day for a few days - tapped it with a hammer every day- now works smooth as when it left West Allis,,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ohiosam Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2023 at 3:05pm
A healthy dose of Kroil fixed it. Thanks for the help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 13 Oct 2023 at 10:11pm
my 180 is the same way...now I know where to look nd hopefully fix the problem....thanks!
