180 making fluid |
Dakota Dave
Topic: 180 making fluidPosted: 15 Feb 2022 at 10:43pm |
I got a new transmition drain plug drilled the center ut and taped it for a pipe fitting. The hydraulic is already a pipe fitting put a close reduced close couple a t on itplug in bottom and barbed fitting out the side. I used a street L and barbed fitting in the tapped trans drain plug and clear tubing between the 2. Had to get the yrans drain plug from AGCO it's not a standard thread i think the ug was aroud 10 dollars when i got one. You could just use yhe plug you e gof snd put a pipe ug in when you want to go back.
orangereborn
Posted: 14 Feb 2022 at 9:37pm |
Anyone care to share what they used/have seen to adapt the case holes to a line fitting. 180 starting to transfer but am hoping to get by w/o Hi range. Snow plow/loader tractor so should be okay until warmer weather....But just in case...Thanks...Dale
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3649 |
Posted: 02 Oct 2016 at 7:33pm |
there is no real issue in connecting the two compartments for a while. - The issue is some thing blew the seal - usually a high side sealing ring sized or the housing is worn - which will lead to burning the high range clutch at the least. Oil for the clutch is supplied to the drilled housing and sealed by 3 piston rings. Somethings wrong...or going wrong
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 02 Oct 2016 at 6:54pm |
You need to split the tractor to change the input shaft and PTO seals.
MACK
Posted: 02 Oct 2016 at 6:32pm |
Just don't run it in Hi side of PD and should not transfer oil. MACK
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34617 |
Posted: 01 Oct 2016 at 8:09pm |
Thats what a previous fellow did to a 170 I have.
rudyk
Joined: 20 Apr 2016 Location: camdenton,mo Points: 151 |
Posted: 01 Oct 2016 at 7:54pm |
Can I tie drain plugs together to get me by
DanD
Posted: 01 Oct 2016 at 5:35pm |
A One Eighty has external lift cylinders for the lift arms. That's not the problem. I believe the usual problem is the oil seal between the transmission reservoir and the power director/hydraulics. Someone else will chime in with more. |
rudyk
Posted: 01 Oct 2016 at 5:09pm |
I heard of people tying them together temporairly
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6061 |
Posted: 01 Oct 2016 at 5:04pm |
Sounds like the hydraulic line going to the lift cylinder is leaking. I would try lowering the lift all the way and seeing if it slows down or gets worse if you go all the way up. I don't know the number serries that we'll but it is a pretty common problem with the d serries and I think you have to split it to replace the line not sure.
rudyk
Posted: 01 Oct 2016 at 5:01pm |
Hydraulic
Dan73
Posted: 01 Oct 2016 at 4:49pm |
You talking motor oil or hydraulic oil?
rudyk
Posted: 01 Oct 2016 at 4:28pm |
My 180 started pumping fluid out the breather/dipstick by the gear shift
The other was low Filled it up and within a hour low again Is there a quick fix for this or is it split the tractot |
