180 hard shifting power director? |
allispicker
Topic: 180 hard shifting power director?Posted: 02 Jul 2019 at 7:32am |
My 180 has been getting really hard to shift the power director from high to neutral. Low to neutral works fine and neutral into high is fine. Once it’s in high it takes a lot of effort to pull it down into neutral. Any ideas? Thanks
Posted: 02 Jul 2019 at 8:27am |
Oil the handle pivot bushing and detent ball with WD40.
allispicker
Posted: 02 Jul 2019 at 8:39am |
Where is the detent ball located? Behind the side panel/under the steering column? Thanks.
Posted: 02 Jul 2019 at 9:03am |
Spray uphill with a plastic stem works best.
If you can't figure it out take the top off of the instrument panel.
Edited by DrAllis - 02 Jul 2019 at 9:09am |
allispicker
Posted: 02 Jul 2019 at 9:40am |
Will do, thanks!
MACK
Posted: 02 Jul 2019 at 9:07pm |
The housing that holds the detent gets worn to where it tries to follow lever and locks in. MACK
caledonian
Silver Level Access
Posted: 02 Jul 2019 at 10:04pm |
Oiled our with wd40. Works every time,
allispicker
Posted: 03 Jul 2019 at 6:47am |
I pulled the instrument cover off and sprayed oil on the detent spring like Dr. Allis prescribed and it now it shifts really easy. Thanks for the advice!
tbran
Joined: 14 Sep 2009 Location: Paris Tn Points: 3649 |
Posted: 03 Jul 2019 at 9:31am |
beware! IF the roller has a groove worn in it or the cast iron piece with the slots in it , it can cause the lever to pull back some, thus possibly reducing the pressure on the high side cultch and causing slippage. Happened to my 185 that had lots of hours and usage.
70254663 , that is the late series - the early series had a ball that detents in the grooves of the quadrant - we have seen the same thing on the early type letting the lever pull back. To check simply push the lever forward and see if it can be moved a significant amount.
Edited by tbran - 03 Jul 2019 at 9:36am |
