180 gas to diesel swap
Jason n View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jason n Quote  Post ReplyReply Direct Link To This Post Topic: 180 gas to diesel swap
    Posted: 22 hours 50 minutes ago at 5:55pm
I have a 180 gas tractor with the 265cu gas engine and I have a gleaner F with the 301 non turbo diesel in it. What parts do I need to put the 301 diesel in my 180 gas tractor??
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 22 hours 8 minutes ago at 6:37pm
Use the tractor flywheel but transfer over the combine ring gear to it. Use the tractor oil pan and probably oil pump too.  You'll need a diesel tractor front cover and front engine plate, which requires pulling the camshaft to swap. There's more than one front plate when it comes to the injection pump mounting area, so get the right one. You'll also need the air tube from the air cleaner to intake manifold and turn the air cleaner around the other way. I think the gas water pump will also need to be transferred to the diesel.
tbran View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 12 minutes ago at 8:33am
As Doc sez make sure you have all the right parts first. I will be a good swap. There are two different oiling systems on the 301's  only the first ones had the bayonet type cam driven oil pump. The late ones have the crank driven oil pump - this can be seen by  a noticeable bubble down in the pan on the crank shaft or front end. We have done a bunch of swaps and use the deep pan - by cutting off the pivot  bushing and raising it  up the length of the bolt holes in the back mount bracket and adding a plate to the top and drill holes to move the back support down to clear the axle. This might not crank as well in cold weather but the fuel savings will be real. Plus there are not many parts to support the G265 should a failure occur.
