180 gas no start
Randalshmandal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randalshmandal Quote  Post ReplyReply Direct Link To This Post Topic: 180 gas no start
    Posted: 25 Jun 2021 at 8:56pm
Hello, just bought a Mahindra 2538 38hp tractor.I have 8 acres of field grass to keep manicured but first have A LOT of 1-2 inch wide garbage I need to clear mostly around perimeter of property line against neighbors trees. I heard flail mowers with Hammer Heads not Y blades work best on brush because they cut almost right down to ground not leaving Puji sticks all over to puncture your tires or stumble over at the least. Any thoughts on this? Will the flail mower with hammer blades cut the field grass good? What type mower has the best drivetrain protection? Thanks
Mikey9455 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikey9455 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2021 at 11:26am
My stepdad Has a 180 with 6 cylinders gas engine he changed points and it will not hit a lick points are set correctly it Is getting fire to the plugs but will not even try to start it was running before he changed the points I've did all I know to do
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2021 at 5:33am
Welcome to the Forum.
Your question should be on the Farm Equipment Forum to get the most exposure.  This forum is for discussion of forum changes and ideas.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2021 at 7:01am
I agree with JimME. You should post in the Allis Chalmers Farm Equipment section. This section is for the technical part of the forum (trouble posting, notifications, posting pictures, etc.)
Did you change the condensor, too? May have a bad condensor. Most of them are foreign made and it's not uncommon to get a a bad one.
Other than that, make sure none of the wires are grounding out on the side of the distributer and make sure the coil wire is seated in both the coil and distributer cap.
Did you change the wires on the distributer cap and, if you did, are they installed correctly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jul 2021 at 7:05am
After I reread your post, I see that you are getting fire to the plugs, which means it is either not firing at the right time (plug wires installed incorrectly) or a fuel problem.
Did anyone shut the gas off ?
Play Farmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Play Farmer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jul 2021 at 7:28am
I fought with my gas Massey longer than I care to mention with somewhat the same issue, sort of. Sometimes it would run, sometimes it wouldn't. Sometimes it would seem like it had spark, sometimes it wouldn't.
I finally switched it over to electronic ignition and never looked back. I would **highly** recommend the same.
