180 fuel line
mintenfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Topic: 180 fuel line
    Posted: 11 Sep 2017 at 9:37pm
I bought a 180 last year, a basket case, but I needed the engine. I'm just getting around to fixing the issues before we swap it into a 185. So the things I'm wondering is that it surges, enough to bother me. I put a new fuel filter on it and next I wanna do valves. So I'm wondering what the gap should be. Also does anyone have a 180 service manual PDF that they could send me? THanks in advance.
Edited by mintenfarmer - 14 Sep 2017 at 11:31pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 9:43pm
Set valves at .018 cold. Send the pump to Ed. on this sight. Weight retainer is wearing out.     MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 11 Sep 2017 at 9:45pm
What is ed's turnaround time? Will it hurt if I run it as it is for the time being?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 12:46pm
run it until you can be down for a little while while doing other things.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 1:23pm
Did you get a 'spare' pump with the second tractor engine?
Send that to Ed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 1:36pm
good point, the 185 pump would be the one to rebuild, since you're putting the engine into a 185 if I read that right. The pump is basically the main difference from a 180 to a 185 as far as engine performance goes. The 180 was rated at 2000, 185 2200, and slightly more fuel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 4:29pm
The 185 runs as of now but smokes severely, and has a knock that we think is broken piston skirt, the plan is get the 180 engine fixed up decent for the 185 as the tranny isn't the best any more. And then rebuild the 185 engine for another project.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 10:02pm
Just guessing, but I would say your knock is a scored piston.   MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2017 at 10:27pm
I don't have a video of it, but it sounds like this Broken piston skirt
Edited by mintenfarmer - 12 Sep 2017 at 10:28pm
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 12:47am
Get a boreoscope and investigate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2017 at 7:57pm
I got the valves adjusted tonight, .018 cold. It runs way better, but while cleaning it I noticed that the front injector and the line along the top of the injectors going to the tank were leaking fuel.
Edited by mintenfarmer - 13 Sep 2017 at 7:57pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mintenfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2017 at 11:33pm
The line that goes along the top of the injectors from pump to tank is leaking where there are two little rubber hose pieces in it. Is this just hose i can replace or is it a special hose type. TIA
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 15 Sep 2017 at 6:55am
The hose isn't anything special,but it needs to be rated for fuel and not just something for water. Most any automotive parts store will have what you need.
