180 front rims
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 180 front rims
    Posted: 14 hours 3 minutes ago at 7:24am
My 180 has 9.5l 15 inch front tires on it. they are mounted on implement rims that are reversed so they will clear the spindle. I need to replace the rims, bolt holes are egged out, and was looking for rims that have an offset to clear the front spindle, or guess they are called the knee. Any idea where to start looking? Really dont want to go to 7.50 rims and tires.
Thanks Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 56 minutes ago at 7:31am
Many 200 tractors had 9.5L x 15 front tires. They weren't as tall as 10:00 x 16's.  When they changed the oil pump/oil pan on the 200, the nose went up in the air 2 inches or more, so the 9.5L's tried to level it back out, especially with 18.4 x 34's on the rear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 50 minutes ago at 7:37am
Ruined a rim years ago, Bought online off Fleabay and was exactly what was on my own 180.  Since found a Used one and have Two Sets of my own.
Not sure where will find but were quite prevalent less than 12 years ago.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 13 hours 33 minutes ago at 7:54am
Would a rim off a 200 have an offset that would work on a 180?
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 59 minutes ago at 8:28am
If you're in a pinch and can only find implement rims with the wrong offset, you can usually drill out the spot welds between the centre disc and outer hoop, then knock the centre out and re-position and re-weld to get a different offset. I've done it a few times. A little bit of careful measuring, careful grinding, and paint, and you'll never be able to tell.
Here's a thread on another forum that discusses it: https://www.casecoltingersoll.com/threads/changing-wheel-offset.17267/
Edited by DanielW - 12 hours 58 minutes ago at 8:29am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 28 minutes ago at 8:59am
Yes. 180-185-190-200 front wheels should all interchange.
TedN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedN Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 45 minutes ago at 12:42pm
Last year I put new wheels and 7.50-16 tires on my 190XT and have been happy with them. My old wheels were 8x16 and would fit either direction, unlike the 8x15 wheels that I can find that have a little over an inch offset. You could replace what you have with a new wheel, or you could go up an inch in diameter and try to find a short tire. I don't know what you use the tractor for, but I think if I was doing it I would just replace what you have. New wheels are available and aren't expensive, and most are already an off-white that is close to the right color.
Ted
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 8 hours 31 minutes ago at 12:56pm
Few years ago put new rims on 185. Bought from agco. Made in USA, well made, correct offset and color.
PaulSamwel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulSamwel Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 25 minutes ago at 6:02pm
I put 10.00/16's on this 185.Standard 8 inch wheel farm/implement wheel.
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Posted: 3 hours 4 minutes ago at 6:23pm
Think i will look to see if i have a couple of rims and try the take the centers out and reverse them.
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 57 minutes ago at 7:30pm
Couple months ago was looking for new tires for the 200. Took old 4 ribs off and measured the rims, 15x10. Tire guy said he couldn't get a 4 rib 15" wide enough for a 10" wide rim. We settled on a set of 4 rib 10.00/15's. A little shorter but still looks good on the tractor. So make sure your tire size is available for whatever rim you use.
LeonB Mo
