180 front end questions
keith wd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote keith wd Quote  Post ReplyReply Direct Link To This Post Topic: 180 front end questions
    Posted: 26 Apr 2016 at 8:35am
been working hard on the 180 i bought and that the terrible part about it is that the guy that had it last had not used it in 6 years and that when he did use it he never greased the front end and that the grease end on the part of the front end that when going on a hill that the front end will go up or down that pin will not take grease wondering if i have to take the pin out and try to fix the inside of their?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2016 at 10:16pm
Most of the time, that pin will not come out.    MACK
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 7:17am
The pin should be threaded so that a slide hammer can be used to remove it if it's like a 190. Removed the one on Dad's 190XT that but it was a job. Think I had to slide the whole front end out away from the engine to get at it but it's been 25 years ago. He didn't know that was a grease zerk there. I replaced the pin and welded a new pipe with bushing to the axle. That has to be welded exactly right or you won't get it back together. If you go that far it has to be clamped very very well in place and it takes even welding on both sides going at it slow letting it cool between welds and it takes several beads stitched together on each side with good deep heat penetration.
Wink
I am a Russian Bot
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 11:41am
They make a tool for about $60 that goes on the zerk just like a grease gun. You spray some break cleaner or penetrating oil into the tool. THen it has a little plunger you put in similar to a syringe. You lightly tap the plunger with a hammer. and sometimes you can get the fluid to creep in where grease wouldn't. It's gets everything opened up and you can grease it when done.
http://www.northerntool.com/shop/tools/product_200430913_200430913?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Fuel%20Transfer%20%2B%20Lubrication%20%3E%20Grease%20Guns%20%2B%20Accessories&utm_campaign=IPA&utm_content=403100&gclid=CIWflfriscwCFQmSaQodbRMKiQ
Edited by Allis dave - 28 Apr 2016 at 11:41am
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 12:01pm
I bought one of those tools at Harbor Freight. Seems it was in the $5 to $10 range. At that price figured I could afford to give it a try. Seems to work about half the time in clearing out the area.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2016 at 2:38pm
Have what appears to be an older more heavy duty version of that tool that I found in a pawn shop years ago and package advertised it was used to free up fittings you could not pump through.
Take it easy on fittings where there may not be much of a volume area for grease behind the fitting as it can pressure up and force a press- fit, OR threaded fitting completely out.
