180 Engine Heater
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: 180 Engine Heater
    Posted: 26 Dec 2016 at 10:52am
I have an Allis one-eighty diesel I acquired a few years ago. It has a block heater on it and also a heater connected to the water hoses. Why would there be two heaters on it? I have used the block heater, and it does heat the engine up. Just wondering if there is a reason to have both and to use one over the other. Thanks, Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 10:57am
usually tank heaters were used when no place for a block heater. Don't see advantage one over the other. Maybe a low watt block heater VS a 1500wt tank heater?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 12:24pm
bet at one time one whent bad and a differant one got installed and the old never got removed or the cord on the block heater whent bad and the other got put on until a new cord came  or back up    just thinking like some of my customers
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 7:49pm
Could be an old timer that didn't like block heaters. 1 Reason I've heard was they thought would cause pitting on the two cylinders thats next to heater. 2 reason i heard tank heaters heat whole cooling system uniformly because they make coolant flow
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2016 at 8:11pm
You would have to ask one of the previous owners.  Some of them do pretty strange things...
shameless (ne) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless (ne) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2016 at 3:59am
maybe with both of them, they could get it heated quicker in the mornings , instead of having them on all night?
