180 Diesel- Bleeding Fuel Line
dertz19 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Topic: 180 Diesel- Bleeding Fuel Line
    Posted: 01 Jan 2022 at 9:37pm
Bought this tractor about 10 years ago. 1968. 500 loader. Low hours (3,200). Use it less than 50 hrs a year. This is my first diesel. It has ran like a top, so I haven't done a thing to it.
Started surging RPM's and quit last week moving snow(according to my dad- I wasn't there). Got it started again to drive into the shop.
My inclination/ research led to think fuel filter would be the place to start. Replaced that, but long story short I didn't do the bleed/startup process correct initially so now I have to bleed the whole system (I do have an owner's manual- still didn't do it right- should have done more preliminary online research).
Roosa Master fuel pump- I gather there is not a bleed screw on the unit? I've loosened up the injectors maybe 2-3 turns each (front two weren't all that tight and there's more grease build up there- would that be enough to have taken some air into the fuel line?). I've cranked over the starter maybe 6 times at 10-15 seconds each, and I still don't get fuel leaking out of them. Have I loosened the injectors too much or too little? Does it take more cranking of the starter than I've already done?
Any advice appreciated!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2022 at 9:58pm
Doesn't a 180 have a hand primer pump? Loosen plug on top of fuel filter and pump til no more air. Close vent and pump some more. Should be able to hear air bubbles in fuel tank from return. Bubbles gone it should start. Should only need a couple lines loose at the most. It will bleed once running. You won't get a great amount from injector lines. People think they should be squirting but no. If you have fuel coming from line tighten it up.
Your description of dying sounds a lot like the governor flex ring failing and plugging return. If it's old and not been apart forever good chance that's it. Know what your doing before you pull the pump.Timing mark etc.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 4:33am
Always start at he sediment bowl by verifying you have TWO good streams of fuel gushing from the base with the glass bowl removed !!! If fuel can't get out of the tank it will never prime up !! Throw away the screen inside the glass bowl !!.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 10:16am
Theres a bleed bolt on the pump - right out front 1/2 inch wrench - you have  to tap the injector lines to get them to bleed / get the air out
Edited by DougG - 02 Jan 2022 at 1:43pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 02 Jan 2022 at 10:29am
As Steve said, the flex ring is likely failed and pieces plugging the return. Hence the surging. Leave the bolt Doug mentioned loose and see if it runs normal. It may be time for a pump servicing!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 8:08am
Thanks all for the input. Helpful to know about the bleed screw on the pump- the owners and shop manuals don't seem to mention a thing about it that I can see.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jan 2022 at 8:21am
It's not really intended to be a bleed screw, but it can serve the need, usually these aren't that hard to bleed.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jan 2022 at 12:38pm
I've had my 185 lines apart a couple times and never had an issue bleeding or needd to loosen lines. Just I loosened the bolt on top the filter and pumped until the filter was full, then pumped some more. You can feel when fuel gets to the primer. Then pumped some more and it started fine.
Mine had a similar issue as yours. Ed fixed me up this spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote dertz19 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jan 2022 at 9:40pm
Update- finally got it running again. Hadn't thought of needing to use the glow plugs since it sits in a heated shop, but that's what I needed to do to finally get it started. Sputtered and RPM's whacked out for 4-5 seconds, then it evened out and ran perfect for an hour while I worked it moving snow with the loader and blower. Good to know about the flex ring issue in the fuel pump- if it happens again, I'll know where to look. There's some leakage/ moisture around the pump and return line- will monitor that more closely now. Thanks again for the all helpful  input- I appreciate it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 4:53pm
Glad you got it going. I always like to plug my tractors in if it's anywhere around 35 if they have a block heater. They start soo much better.
Edited by Allis dave - 12 Jan 2022 at 4:54pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2022 at 5:29pm
Luv the sound of a 180 w/ the 301 diesel!
This page was generated in 0.191 seconds.
