180 Clutch/PD
NDCurt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDCurt Quote  Post ReplyReply Direct Link To This Post Topic: 180 Clutch/PD
    Posted: 10 Jul 2010 at 1:14pm
Having an issue with the clutch and or PD and I know I've read here before on how to tell but here is what it's doing. Forward motion slows/stops and PTO the same. Mostly when more heavily loaded (almost full bale uphill) it will hesitate and then grab and go. Next hill same. Also when I quit and shutdown had some oil leaking from center just aft of engine. What's going on here? Thanks
PS Glad I got the 185 so I won't get stopped
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2010 at 3:42pm
My guess is your rear main seal is leaking. That makes the clutch slip. That is why it affects the PTO and forward motion. Slippage causes heat which burns the oil away making the clutch grab again until the leak makes it slip again. Hills bring on the extra load.
