180 cast front
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: 180 cast front
    Posted: 14 Oct 2015 at 7:10pm
With all this talk about removing the front end cast piece on a 180-185-190 and placing it with a steal one. Just wondering what the cast piece weighs and how much can be saved making it out of steal
Thanks
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2015 at 8:24pm
180-185's are already hollowed out. 190's are solid cast and very heavy. I'd guess I could build one for a 180-185 and save you more than 100 lbs and probably near 200 lbs. I always try to incorporate the front weight bracket into the new front support to move suitcase weights out farther and hang them sideways for better results..
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 6:51pm
I know that the cast is hollow but was hoping that I could have made it a lot lighter. I about cutting off what I don't need on the front axel but that's not going to lighten it up enough.
With me on my 180 I'm at 7100lbs but I can't get it the lift the front end
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 7:23pm
I consider 200 lbs to be a lot. Sharper rear tires would help too. More weight behind the rear wheels also helps. Drawbar pull point at a SOLID 20 inch height, not a clevis that sags.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 7:28pm
I set the drawbar at 18" from the axle and 20" high .
When I add weight I place it behind the axle but can't lift the front end up in order to hook.
I'm running 15.5 x38s. I'm running in the 8200 and 9200 lbs using 2 low
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 7:32pm
Removing 200 lbs. from the casting, narrowing the front end up to it's narrowest point and removing some of the steel from the telescoping axles, lighter front rims with smaller tires and removing one battery, gives you quite a significant amount of weight to move behind the rear axle.
BIGAL 210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BIGAL 210 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 8:38pm
I took the factory front axle and cast block out of my 210 and put a narrow front end under it and lost 1000 LBS. Hope this may help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 8:54pm
A turbocharger and shifting up one gear will lift the front end too !!!!!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2015 at 8:57pm
Well that's what I'd like to do. How much up can I safely add before smashing rear end. I wouldn't go above 9200 lbs class
8070 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2015 at 9:26pm
I running a 17 with a 301 out of a l3 158 HP put 7080 pump that getting all it can and a 3594 turdo on it And 509 inj use a 170 front it light Ican put it o . And off by hand lighter yet these or both a lot lighter then the 180 . The 170 got abox that only 3/8 steel it may be 75 lbs . But a lot of u prob the 15.5 we had to go to 18.4 then we could get it up u go 250 HP and u be OK we run 5000 to 8500 with this and no end probes but u know if your PD good or not lol and we run 2 hi and some time 3 hi but we run the 6 and 8mph class. the 17 in 2hi is 9 mph so have watch rpms till under a load . U want know more just hit me up .
This page was generated in 0.071 seconds.
