180 aux. valves detent kicking out
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Topic: 180 aux. valves detent kicking out
    Posted: 15 Jul 2023 at 4:36pm
My aux. valves are kicking out at 300-500 pounds on the gauge. the 3 point and all other hydraulics are working normal. Could the o-rings in the hydraulic system relief valve be bad causing this?
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 5:37pm
The detents are adjustable, look in operators manual on how to do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 7:23pm
With the engine throttled up to at least 1700 RPM, and you have a gauge plugged into a remote outlet, activate the lever that will make the gauge move, and hold that lever fully into raise or lower, you should have 2,000 to 2,200 psi on the gauge. You say you only have 300 to 500 psi ?? A new or rebuilt relief valve is the first step to repair it. You also say the 3-point hitch works fine?? Well, you don't have anything heavy hanging on it. It takes nothing to raise an empty hitch. 500 psi won't lift much of anything on the 3-point which uses the SAME relief valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 7:48pm
Doc, The 3 point will pick a 1200# bale but, the aux. won't pick much on the front loader.
  KJCHRIS. I've tried to adjust the detent but, it doesn't change much all the way screwed down.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 7:56pm
Coupler problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 8:22pm
I'll try them but, it happened on both spools at the same time. All was working fine then, I used the batwing mower for a few days and I was trying to fold  up the batwings and this started. I did toy with the idea of the couplers but, just found it odd to happen on both spools at the same time. Does act like couplers since both detents kick out. If I ease in the the control handles real slow they hold in longer.
Edited by ksbowman - 15 Jul 2023 at 8:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2023 at 8:45pm
Easing in on the spools and then weakness is always the relief valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 11:47am
Doc, Is the relief valve on the 170 the same as a 180? My 170 works fine and outwardly they look the same. For a test before ordering parts I am thinking of pulling the one off the 170 and put it on the 180. If that corrects it I'll order parts for the 180.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 12:02pm
Same exact relief valve cartridge assembly. Located on the left front corner of the hydraulic valve stack.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2023 at 5:08pm
Thank you Doc, That fixed it. 2300# on the pressure gauge and the 500 loader picks the front tires off the ground again. Now to tell on myself, first I rebuilt the "Traction Booster" relief valve and while I was doing it I kept thinking of your last post saying the relief valve was on the left front of the spool assembly. I looked in the cab and there it was. Pulled it apart replaced the O-Ring on the piston, reassembled and it works perfect. We are so fortunate to have you as a mentor! Flawless diagnostic work from afar.
