18 hp Kohler 361
DaveWisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Topic: 18 hp Kohler 361
    Posted: 10 Nov 2024 at 2:59pm
May need a head for this engine it is a single cylinder overhead valves Kohler anybody gave one
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2024 at 7:19pm
not many survivers  left
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 8:03am
I have had it for years since 1983
Coke-in-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2024 at 8:42am
I have 2 - 16HP Kohlers K341 I have rebuilt only to have problems with later - replaced with HONDA 18 HP engine and works good - only problem was Honda air cooling sucks grass clippings up and plugged air intake = had to put screen under engine to keep intake clean .
 Might look at Harbor Freight engine in size - put one om my small tiller and works good and cost is affordable .
"Challenges are what make life interesting; overcoming them is what makes life meaningful."
55allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 21 Nov 2024 at 11:12pm
Are you trying to get rid of the Kohlers? What problem do they have?
I haven’t had a lot of problems with Kohlers ….
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveWisc. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2024 at 12:39pm
The 361 is sometimes a problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 23 Nov 2024 at 7:42pm
any high hour kohlers with balance gears wont last long if the balance gears and the balance gear shafts bears and shims are not replaced just doing the bore, crank and piston wont cut it
Post Options Post Options   Thanks (0) Thanks(0)   Quote 55allis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2024 at 7:52am
I just plain remove them balancers gears, if the engine hadn’t removed them it’s self…
I had a k341 and a k241 remove the gears themselves and I had to patch the hole in the block, both run fine now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2024 at 7:26pm
i think thats why the 12 hp kolher last good i just dont think they need all that stuff spinning aroud in their   they might make a little more torque like  a big flywheel
