18.4 X 28 Tires for 6070
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Topic: 18.4 X 28 Tires for 6070
    Posted: 25 Sep 2019 at 9:28pm
I am looking for a set for a 6070 haying tractor. An off brand would be fine, don't want to spend a lot. Any recommendations would be welcome.
rieg
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 7:46am
Good luck!  I am watching this post with intrest.  Changing to 30 inch wheels or go back to 16.9x28, may be the best solution.
Edited by WNYBill - 26 Sep 2019 at 7:48am
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 9:13am
Most 6070 tractors came with 16.9 34 tires. 18.4 28 tires are way too short, about 7 1/2 in dia. 18.4 30 tires are around 2 1/2 inches shorter.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 9:15am
Find a dealer that sells BKT brand tires. They are usually cheaper and I've had good luck with them.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 9:53am
Charlie
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 8:35pm
1) Those tires are way too small one of 6080’s run 16.9x38’s the other two 18.4x34.
2) You get what you pay for in tires I’ve bought cheap tires and got cheap crappy tires. Buy Firestones and have something decent.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 8:52pm
New tires are expensive to buy, but you will not need to replace them in 2 or 3 years if you go with used tires.
Dave Wisc. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Wisc. Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2019 at 5:24pm
I got a set of 18.4x34 not great but good tired and no breaks.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 7:27am
Thanks guys my 6070 is fwa and the front tires are 11.2 X 24 so I think I am going to have to keep the 18.4 X 28. The tires on it now are weird 18.4 X 15-28 the rim measures 17 outside to outside and 15 3/4 inside bead to inside bead. Alliance brand any suggestions? Thanks
rieg
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 8:28am
rieg; 15x28 is the old designation that became 18.4x28. Some manufacturers, (maybe all) put both on tires for a time. Now they are switching over to metric measurements and I'm seeing something like 480x38, replaces 18.4x38.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2019 at 11:14am
Put Alliance on my 6080 ran them roughly 3 years they cracked like crazy took them off and put Firestone on much happier. Firestone also has better grip.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2019 at 6:04am
BKT and Alliance are comparable. The TR135 is a cheap tire, you get into the radials on both and the quality is way better on both brands. I was selling Alliance 20.8 radials $600 per tire cheaper than Firestone’s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2019 at 8:58am
I have a pair of 18.4X28 Firestones that I’d sell. I’m in Maryland, very near Gettysburg, Pa.
rieg View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rieg Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2019 at 9:06pm
Tempting Paul, pm me lets see what you have.
rieg
Missouri TOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Missouri TOM Quote  Post ReplyReply Direct Link To This Post Posted: 02 Oct 2019 at 2:33pm
I had to buy one for my 6080 and "ADVANCE" was the cheapest one i could find and it was $600.00 and seems to be a good tire.
