17D starter |
Elvin
Joined: 17 Sep 2012 Location: Winchester, KS Points: 58 |
Topic: 17D starterPosted: 15 May 2025 at 6:39pm |
Dr Allis ? Does someone make a Gear Reduction Starter for a D17 Diesel ? Can you remove a canister oil filter base and mount a Spin-On base ? Thanks, Elvin
Posted: 15 May 2025 at 7:35pm |
Oil filter base shouldn't be an issue. A newer gear reduction starter?? I have no idea.
Joined: 11 Sep 2009 Location: illinois Points: 89135 |
Posted: 15 May 2025 at 9:10pm |
ebay.... ???
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34430 |
Posted: 16 May 2025 at 6:40pm |
NEW IMI HIGH PERFORMANCE STARTER FITS ALLIS CHALMERS D SERIES 262 58-62 APS3882
$ 211.86
Replaces Part Numbers & Specifications ALLTECH: 104-3882 1043882 Product Notice As a parts distributor we mostly sell aftermarket parts (any OEM parts would be noted as such). Aftermarket parts are not sourced from the original vehicle or equipment manufacturer, but are designed to function the same as - if not better than - the original. All parts sold are new. |
AC720Man
Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5311 |
Posted: 16 May 2025 at 7:06pm |
I have a D17D, spins over quickly. The key is good grounds and heavy battery cables. 2/0 welding cable with crimp connectors works best with the correct + and - terminals. They are a different size and it makes a world of difference. Not only on a diesel but gas as well. My WD suffered from a slow roll over until I changed all that out. Just started it today after winter hibernation and she spun over quickly and fired right up. 6V battery and didn’t even trickle charge it. I’m telling ya, it makes a world of difference.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7568 |
Posted: 17 May 2025 at 8:21am |
Get the old starter rebuilt and it will be as good as new
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3122 |
Posted: 17 May 2025 at 12:09pm |
I've used those newer style starters on my Olivers,they'll turn the motor faster than the originals and seem to need less battery power.
