175’s next
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Topic: 175’s next
    Posted: 27 Dec 2023 at 8:04pm
Had to remove pre cleaner, muffler and sun shade brackets to get into shop. Precleaner has 18” pipe making the complete unit 24” high. Seems excessive to me, opinions on height? Need to clean, degrease and inspect. Also how many hours do you experts run your fuel filters? I have 5 years and 280 ish hours on this filter. She is used to mow, rake and tedd. Also has 180 hours on hydraulic filter with new hytrans oil then 3 years ago (60 hours per season)   Opinions on if this filter should be replaced. Thanks y’all. Dana
Blue Skies and Tail Winds
                          Dana
Dave76 View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave76 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 8:18pm
All your tractors look very nice and well maintained.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 8:23pm
Nice unit. I would replace the fuel filter.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2023 at 9:47pm
When in doubt, replace the filters.  After you take the fuel filters out, you will be able to see how dirty they are.  Make sure there is no rust or crud in your tank.
My pre-cleaner is about 24" high.  What makes you think that's excessive?  It came from the factory that way, why change it?  The higher it is, the further away from the dust it will be.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Dec 2023 at 4:37am
Dseries4 I think if it was any lower it could hinder seeing objects in front up close. I didn’t know they came from factory that high. Thanks.
                          Dana
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2024 at 7:13am
Wow that's a tight fit. I thought the heat houser windshield 1/2" from my overhead door was bad
Lookin good as always!
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
