175 "making" oil
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: 175 "making" oil
    Posted: 21 May 2022 at 9:34pm
I checked the oil in the 175 today and it was over the full mark a fair bit.  It does not get used very much.  It does smell like diesel.
I put a new mechanical lift pump on it when I restored it in 2015.  I did put a rebuild lit in it about 3 years ago.  Tractor runs beautifully, never had any problems with the CAV injection pump.  I am thinking of putting on a new lift pump, but is there anything else that could be causing diesel to get into the oil?
Many thanks!
Tom59 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom59 Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 10:19pm
I bet the seal out on the front of the injection pump where it bolts on at the front of the engine. I had a MF275 tractor do same thing with a CAV injection pump and a pump rebuild solved the problem.
nickia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nickia Quote  Post ReplyReply Direct Link To This Post Posted: 21 May 2022 at 10:20pm
If that tractor has the perkens engine my brothers leaked fuel into the crankcase on the back side of the fuel pump
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 6:04am
i'd be looking at the lift pump.
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 1:21pm
Yep a complete pump rebuild and injectors also. Just did my 175 a few months ago. Another reason to pull the dipstick every time before use.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 22 May 2022 at 7:51pm
2 places I can think of: lift pump or injection pump shaft seal.
