175 Hydraulic Remote Valve interchangeably
MisterDRH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MisterDRH Quote  Post ReplyReply Direct Link To This Post Topic: 175 Hydraulic Remote Valve interchangeably
    Posted: 2 hours 40 minutes ago at 12:56pm
I have a 175 with a seized remote valve that is being stubborn.  I’ve had in a press with 5 ton of pressure on it without breaking the valve loose.  It has been soaking for a week in various penetrating oils.  I am now looking at finding a used replacement and am wondering about remote valve off different models manufactured in the same period.  Are the remote valves on 170s, 180s, 185s or 190s interchangeable with the remote valves on a 175?  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MisterDRH Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 2 minutes ago at 2:34pm
The section assembly number for the remote cylinder valve for the 170 and 175 is 242543-7.  This is the part number for the complete remote valve assembly. Does anyone have a 180, 185, or 190 parts manual to check this number against?  Thanks
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 55 minutes ago at 2:41pm
The valve sections are common with most of the other 100 series models.  I got a new section around 10 years ago from my local hydraulic shop around 10 years ago.
