175 Diesel |
Post Reply |
youngorange2000
Silver Level Joined: 27 Mar 2019 Location: eastcentral MN Points: 308 |
Posted: 21 Apr 2021 at 11:25am |
IMG_20210420_171815201_HDR~2.jpgIMG_20210420_171815201_HDR~2_2021-04-21_11-18-09.jpg Judging by the drawbar I don't think it was worked too hard. Starts right up and runs like a swiss watch all the gears feel good has dual sets of remotes and 6 front weights I know that these are kinda a sought after small tractor I would be looking at it to possibly run a 9foot haybine and cultivate vegetables and rake hay with. The tac is broken and reads 7k on it however it seems to be a real tight tractor maybe it was a auger tractor? Tin is straight with the exception of the back of the fenders there are dented SN 1299 so it's a early one. Is it worth it at $4k?
wheatbreeder
Orange Level Joined: 12 Sep 2009 Location: Harrow, Ontario Points: 580 |
yes
Farm stuff 8050,6690,175,F2,5050,WD
darrel in ND
Orange Level Joined: 22 Nov 2009 Location: Hebron, ND Points: 8595 |
I'd say it is! Darrel
allisbred
Orange Level Access Joined: 28 Mar 2015 Location: Hanover Pa Points: 1011 |
Very nice tractor to do what you want. Price sounds good but you may want to check out a possible front leak. Serial number sounds close to mine, may be the 4.236 motor. Mine has been a nice tractor other than the wiring harness is toast.
youngorange2000
I checked out the leak its the steering ram seal, if they are anything like my 7020 was I rebuilt mine for $60 in about 30 minutes
Calvin Schmidt
Orange Level Joined: 11 Sep 2009 Location: Ontario Can. Points: 4515 |
Defiantly worth 4K . We have telahandlers with 15k hours on a 236 Perkins
AC7060IL
Orange Level Joined: 19 Aug 2012 Location: central IL Points: 3224 |
It’s got the front racing stripes decal - Crop Hustlers model @ 62hp - nice tractor. Only diesels offered in the Crop Hustlers. Yes it’s worth $4k.
Tom59
Bronze Level Joined: 27 Feb 2021 Location: Lebanon Tenness Points: 150 |
I think it worth the money specially the way you describe the tractor. The way some equipment selling this winter think it be hard to find anything for less than $4000.
BigGuy1000
Bronze Level Joined: 06 Dec 2013 Location: NWIL Points: 108 |
Yes worth 4K but will have some wiring problems, Steve in NJ does not have wiring harness. If starter does not engage always, switches and wire connectors are bad, bypass with added solenoid to fix!!! Also that Donaldson air cleaner is too small for that engine, will cause rapid engine wear due to dust intake, mine had to be overhauled twice in 10 years!!! If you use for chopping, baling, disking, dirty work, install a Turbo or other above hood air precleaner!!!!!
Orange Level Access Joined: 12 Sep 2009 Points: 19714 |
Diesels, when used in high dust/dirt conditions will require more air filter maintenance than a gas tractor. They consume more air per hour. So, it's always advisable to have a "pre-cleaner" above the hood (especially on a diesel) to help sort out some of the dust and dirt before it gets to the air filter itself. As far as the size goes, it is the exact same air cleaner assembly as a 180/185, so I don't think it's too small. It just will need more attention if it isn't equipped with a pre-cleaner in dusty conditions.
BigGuy1000
BUT: According to an engineer at Donaldson whom I talked to long ago(1980s), that cleaner is too small for that CID diesel engine!!!!!
Well then, according to him, it was too small for a 301 engine in a 180/185 as well.
BigGuy1000
Well perhaps he was trying to sell some, but in any case, a Turbo fixed the problem, no more problems in 30+ years....
allisbred
Turbo on the 175? Like the idea because I think it is kind of weak. What needs changed, I was told before the block was different for the turbo 236 engines?
FREEDGUY
Orange Level Access Joined: 15 Apr 2017 Location: South West Mich Points: 5391 |
Twice in 10 years ??? You've got other issues going on !! Don't blame the air cleaner
He's referring to a "Turbo" brand name pre-cleaner above the hood, not a turbo-charger.
Post Reply | |
