175 Diesel hydraulic vent
atucker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote atucker Quote  Post ReplyReply Direct Link To This Post Topic: 175 Diesel hydraulic vent
    Posted: 01 May 2023 at 4:16pm
Dad has a 175 that has 2800 hrs on it and he bought it for $1,000 from the original owner. He got the manual and the delivery ticket with it. We split it this weekend and replaced the seals around the shafts because it was transferring oil between the rear ended and hydraulics. We started it and ran for awhile and the hydraulics had pressure built up when we pulled the dip stick. Should there be a vent in the dipstick or somewhere?
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 4:47pm
Yes, the vent could be plugged - it's in the top of the dipstick.
Post Options Post Options   Thanks (0) Thanks(0)   Quote atucker Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2023 at 4:51pm
We have a 170 that has a vent on the dipstick but this 175 does not look like the on on the 170
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 5:48am
Regardless, the vent is in the dipstick head. If it has a cotter pin thru the tube, remove it and drop out the ball bearing and throw them both away, Use compressed air to blow up thru the tube and see if you can dislodge the blockage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote atucker Quote  Post ReplyReply Direct Link To This Post Posted: 02 May 2023 at 4:40pm
I just looked at it and is made differently. Someone switched the stick I will have to get one. Thanks
This page was generated in 0.434 seconds.
