175 converted to 1000/540 pto
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: 175 converted to 1000/540 pto
    Posted: 16 Feb 2012 at 2:35pm
I have a parted out 185 with the dual pto (hydraulic actuated) and was wondering if I could put it on one of my 175's without any modification or different parts? I know the rear housing needs to be changed....Might be kind of useful with the Howard Select-a-Tilth rotovator.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 4:50pm
You can install it if you want.....the results will be the 540 will run about 300 rpm and the 1000 will run 660 rpm at full throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 5:01pm
So you are saying the shaft from the pto clutch turns faster on a 185?
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2012 at 5:13pm
Yes.....all 540/1000 rpm tractors are originally 1000 rpm up front.
