175 carb needs rebuilt
jbirnsch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Topic: 175 carb needs rebuilt
    Posted: 22 hours 36 minutes ago at 1:18am
Is there a carb kit worth bringing home anymore? Needs the full kit. Steiner? Do I just go to AGCO?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 hours 60 minutes ago at 5:54am
AGCO I don't believe will have a "kit" anymore. The 175 carb is kind of an orphan model Marvel-Schebler. AGCO might be the only place to buy a throttle shaft if they even have it. The gasket set parts should be the same as a late D-17 IV. The needle and seat is 70226458 the same as a D-17.  EDIT:  AGCO shows 70226470 for a gasket kit and 70251721 for a repair kit. Whether they have them anymore, I have no idea.
Edited by DrAllis - 17 hours 25 minutes ago at 6:29am
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 16 hours 4 minutes ago at 7:50am
If the Doc’s suggestion doesn’t pan out, I have been getting kits from Mikes Carburetor. If you have the carb number you will likely find it on their website.
I got a kit for my Allis FT20-25 and IHC grain truck which has the Holley governed four barrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 56 minutes ago at 7:58am
Both numbers Dr gave are still available from agco
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 15 hours 36 minutes ago at 8:18am
But, neither one have a throttle shaft in them. 70251709 is the throttle shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jbirnsch Quote  Post ReplyReply Direct Link To This Post Posted: 11 hours 35 minutes ago at 12:19pm
Thanks for the PNs. I’ll get on order.
