175 Brakes part II |
| Author | ||
TomYaz
Topic: 175 Brakes part IIPosted: 30 May 2021 at 4:37pm |
Ok new thread to "reset dicussion"...
So I got a pic of the existing arrangement. So what is the gap supposed to be between the line arrows? ![]() |
| Sponsored Links | ||
Posted: 30 May 2021 at 7:31pm |
When fully assembled on the tractor and rust free and able to slide side-tp-side, no less than .020" and ideally no more than .030". Feeler gauge works just fine.
TomYaz
Posted: 30 May 2021 at 7:34pm |
So thats less than 1/32"...looks like we are WAAAYYY off in the pic no? |
Posted: 30 May 2021 at 8:14pm |
A mile off.
Alex09(WI)
Joined: 15 Mar 2012 Location: CECIL WI Points: 1779 |
Posted: 31 May 2021 at 8:57pm |
You will need some shims behind the friction plate to take up the gap to the proper spec. They are the same shims as in the differential bearing carriers. Should be a lot of them out there.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
TomYaz
Posted: 01 Jun 2021 at 6:51am |
Alex, Can you draw me on the pic where you are talking about....
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2494 |
Posted: 01 Jun 2021 at 6:55am |
It's the piece below the brake drum in your picture. It will either need to be replaced or surfaced. And those bolts are going to be a problem too.
TomYaz
Posted: 01 Jun 2021 at 6:56am |
Edit...ok see what your saying...Weird though,,,you have to unbolt the friction plate, install the shims, then bolt back on...to what torque? Then if not right, rinse and repeat..sounds like a pain in the ass....Wonder why this was soooo way offf? Factory or someone who doesnt know what they were doing (like me)??? Going to take a LOT of shims I guess... Edited by TomYaz - 01 Jun 2021 at 6:56am |
Posted: 01 Jun 2021 at 7:54am |
It looks to me like your brake drum assembly is stuck on the splines, if it is holding itself that far away from the outer friction surface. You've got to have clean splines on the shaft and drum so things can slide freely. If this was a non rust bucket, that drum would be sitting clear down and there would be zero gap in the picture.
TomYaz
Posted: 01 Jun 2021 at 8:02am |
Yep the whole wheel was frozen. I think the opposite end of the drum was frozen to its mating piece marked with X ![]() |
TomYaz
Posted: 01 Jun 2021 at 8:04am |
Yes the drum wont budge manually. Advice on how to free? dare I say crowbar?
Posted: 01 Jun 2021 at 8:08am |
Large bearing puller with long legs a crossbar and a screw to pull against the end of the shaft. Never seen anything that rusty. It's like it's been laying on the bottom of a salt water ocean.
TomYaz
Posted: 01 Jun 2021 at 8:26am |
Where the heck do I find a gear puller that large?! Yeah this tractor was/is derelict. Not sure if even proceeding is worth the trouble. I got it and the loader for $800.00
Alex09(WI)
Posted: 01 Jun 2021 at 8:55am |
The spec where you see the inside micrometer should be 2.034-2.044". OR- with Dr's method, .020-.030" of combined clearance with brake drum installed. ![]() |
www.awtractor.com
TomYaz
Posted: 01 Jun 2021 at 9:15am |
>>>The spec where you see the inside micrometer should be 2.034-2.044". OR- with Dr's method, .020-.030" of combined clearance with brake drum installed. Ohh man am I confused...Based on you pic, both sides of that friction(7) plate is exposed... the one side has a gap between it and the drum, supposed to be .020-030 per Doc, and in the other side per your pic show there is a 2.034" clearance....according to the illustration isnt a shim supposed to be on one of these sides. Also in the illustration, the face of part 7 faces the drum, but in your pic it is facing part #1 of the differential?? Edited by TomYaz - 01 Jun 2021 at 9:18am |
TomYaz
Posted: 01 Jun 2021 at 9:28am |
In my pic the bevel side of the friction plate faces the brake drum, while in your pic the beveled side of the friction plate faces the differential part 1....???
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7643 |
Posted: 01 Jun 2021 at 9:36am |
Shims go behind #7 on the axle side, so you do not see it in the pictures. There are 2 ways to get the clearance. One is pictured above to get around 2.034 (without the drum in place). The other way is with the drum installed and using a feeler gauge to get .020 - .030" - I usually use this method.
TomYaz
Posted: 01 Jun 2021 at 9:44am |
??? If you look at Alex pic, the other side of 7 would find the drum! Why is the beveled side faceing the differential while on my pic the bevel side faces the drum?? What am I not getting? Sorry guys I am just not the best wrench monkey like you are; this stuff doesnt come naturally to me.
TomYaz
Posted: 01 Jun 2021 at 9:46am |
Wait a minute.....I suppose the drum goes where the micrometer is....
Geeezzzz like I said, this stuff aint easy for me....
DSeries4
Posted: 01 Jun 2021 at 10:24am |
Yes, the drum goes where the micrometer is. Fit it together and take your measurements. Then remove the axle to adjust the number of shims as needed.
TomYaz
Posted: 01 Jun 2021 at 11:30am |
Given all the work to be done, no way in heck I will get this tractor done soon enuff for me to use. Think I will tear it down, get another 175 that is functional and put the loader on it. Use this unit for parts or make it a leisurely rebuild someday....I would have the other 175 to help tell me how to put it together!! Thanks for all the help fellas. I am going to offload this thread for future use.
