175 Brakes Educate me...
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: 175 Brakes Educate me...
    Posted: 12 Oct 2020 at 6:41am
So I got the final drive off the frozen side....Looking at the brakes...
Being a WD45/D17 owner I can understand the break bands...but it appears there is a disk brake component too?  How does that all work???  Also what tool would one use to remove the break band pin??
Thanks
Tom
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:09am
The disc has balls with ramps inside. When the band tries to stop disc, it causes disc to expand, applying brake pressure on both band and disc.        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:17am
Top band pin is (in your case) probably removed with a torch. Bottom pin stays installed.
Edited by DrAllis - 12 Oct 2020 at 7:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:23am
Ugg...before I resort to that looks like the end of the pin has a groove for a tool to be attached for pulling...what kind of tool would that be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:26am
Two screwdrivers. If it was anti-seized, it will come right out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:29am
Ok....its rusted up good....but I got a lot of time and pb blaster
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:33am
There was a guy that made a tool to remove the WD45 pins but I don’t know if these are similar. Can’t remember if he was on this site or not but it was an expensive tool.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:41am
Its similar in that it has a groove IIRC, but smaller dia.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 7:53am
And it isn't exposed, it's down inside a recess.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 9:33am
I have used a small cutoff wheel to remove the shoes from the top pin.  After that, I get the heat and penetrating oil out.  If it really has problems moving, I have cut the pin in half and dealt with one half at a time.
It is a combination brake system.  The shoes do not stop the tractor directly.  They close against the disc.  The disc will expand to put pressure on the bearing carrier and the friction plate on the axle, making the tractor stop.  Definitely take the dick apart to check the balls inside.  If they are worn, the assembly will not work properly.  Once everything goes back together, you will need to use a feeler gauge to check the clearance between the disc and friction plate.  The specs are outlined in the service manual.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 12:40pm
I made tool that clamps onto the head of the pin. A small slide hammer is then used to pull the pin.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Oct 2020 at 2:23pm
Sometimes typos are hilarious!!!
