The Forum Parts and Services Unofficial Allis Store Tractor Shows Serial Numbers
175 Allis steering problem
Mooreje1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooreje1 Quote  Post ReplyReply Direct Link To This Post Topic: 175 Allis steering problem
    Posted: 22 Sep 2022 at 9:33pm
I have a 175 Allis with steering problems. Remotes and lift arms work fine but the only way to steer it is to just keep turning the steering wheel and use the brakes. Anyone have any ideas what’s going on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2022 at 9:38pm
Sounds like the cylinder is leaking internally. JMHO Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2022 at 10:01pm
Yup what Tracy said. Take the steering ram and have it rebuilt.
Welcome to the forum
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooreje1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 6:22am
Ok thanks for the help. I’ll take the steering ram and have it rebuilt.
Post Options Post Options   Thanks (1) Thanks(1)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 6:40am
Probably the problem BUT, you should disconnect each steering hose at the ram and PLUG THEM first. Then, see what you have. You should have great difficulty turning the steering wheel. If you do not, you have a pump issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooreje1 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2022 at 12:49pm
Ok I’ll try that thanks
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Sep 2022 at 4:52pm
The pump has a separate section for the power steering. There is also a relief valve between the pressure and return lines to the steering valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooreje1 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 2:40pm
I plugged the steering lines at the steering cylinder and you can’t hardly turn the steering wheel so that tells me it’s the cylinder. I’ve tried to find a seal kit for the cylinder but I can’t seem to find one. Does any have a suggestion where I could get one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 4:59pm
AGCO.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 8:34pm
Not sure Macon has a Agco dealer now but Brookfield does. Not far away.                            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2022 at 10:06pm
I believe it’s seal kit 72073364
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooreje1 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2022 at 6:40am
Ok thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mooreje1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Oct 2022 at 7:47pm
Got the new seal kit put in the steering cylinder. It works great now. Thanks for the help everyone.
