175 & 6080 electrical issues
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Topic: 175 & 6080 electrical issues
    Posted: 16 Jul 2017 at 7:53pm
I'm having a problem with both tractors. In both cases the fuel and temp gauges read wrong. The 175 temp gauge reads low and fuel gauge reads high. 6080 is the opposite. I've been told to check for good ground. Does anyone have any good suggestions on how to trouble shoot this. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jul 2017 at 6:46am
Had similar issue with my 190xt after i painted it. I disassembled most of the tractor and had to remove paint to get to bare metal where the lights attach to the fenders. Also where the fuel tank and fender bolt together in order for the fuel gauge to work., And for the temp gauge to work, I had to remove paint in the instrument panel hole and clean up the outer gauge itself in order to get a good ground. Both gauges work great now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 8:18pm
Today I was planning on clipping pastures with the 6089 so I ran a jumper wire from the ground post on the temp fuel gauge to the negative post on the starter. No noticeable change. It does seem like both work fine until it gets warmed up. Them temp gauge goes up and fuel gauge drops. Anyone have any ideas. My next guess is sending units. Thanks
ctbowles58 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ctbowles58 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 8:35pm
I had the same trouble with my 6080, and a new gauge fixed it.
190XT 2WD45 WF D15 D14 CA BIG10 302 & 303 bailers 77G rake 80R mower 6 plows and alot more
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2017 at 8:48pm
If i remember correctly, disconnect the sending wire to the fuel tank. Ground that post at the gauge with a temporary jumper and the gauge should go to full if the gauge is good. If not replace the gauge. Mine went to full so I replaced the defective sending unit. This was before I painted the tractor. Both of my gauge problems were due to poor ground after the paint job. If you have verified a good ground with a volt ohm meter, check your wiring and make sure you do not have a wire rubbing against metal some where. Test end to end with a volt ohm meter to verify continuity and that a ground doesn't exist. The gauge and sending unit wiring have to be disconnected at each end to perform these tests. Test one wire at a time with one test lead to the wire and the other to ground to check for a ground. If all checks out good, then I would replace the least expensive part first, most likely the sending unit as far as the temp gauge. Bill at Sandy Lake is very helpful when it comes to trouble shooting gauges. If he has time he will walk you thru your questions over the phone. Super nice man and very knowledgeable.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 4:37am
Thanks for the input. The neighbor up the road has a service manual. I may see if it has any more test info. My operators manual doesn't. Just a wiring diagram.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 24 Jul 2017 at 1:16pm
6080 temp/fuel gauge isn't bad last year they were 99 bucks thru Lauf if you need that
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jul 2017 at 12:27pm
Update. I disconnected the sensing wires from the gauges and grounded them. The gauges seem to work fine so I ordered two new sending units. Hopefully that's the fix. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2017 at 6:15pm
Great, let us know the results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 16 Aug 2017 at 9:12am
Well I finally got the 6080 fixed. I changed bothe the fuel and temp sending units and it actually made things worse. I checked the wiring and determined it was good so I ordered a new gauge. Now everything seems to work as it should. Thanks for the help.
Now I need to tackle the 175 but it doesn't get used as much as the 6080.
