172 rotary mower driveline nut
Phillme2 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Phillme2 Quote  Post ReplyReply Direct Link To This Post Topic: 172 rotary mower driveline nut
    Posted: 30 Oct 2024 at 3:44am
Hey I’m looking to get some assistance in trying to find the nut or nut that go on to hold the spring to the slip def on a 160 or 172 mower. I can’t seem to find the size or anywhere to get one. If you have any assistance I’d greatly appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 4:27am
Measure the diameter and thread pitch in tpi and then go to McMaster Carr.  IIRR, you need 2 half nuts and a lock ring. the lock ring can be made out of a thin, keyed flat washer, that is hammered over 3 flats of the first nut, then hammered over 3 flats of the second nut...Wink
Edited by DiyDave - 30 Oct 2024 at 4:28am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 30 Oct 2024 at 7:47am
Welcome to the forum.
Do you have the spring. Then there’s a special washer and two nuts. I’ll look. We should have all three things if you need
This page was generated in 0.139 seconds.
