170-175 plow capacity?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 170-175 plow capacity?
    Posted: 25 Sep 2025 at 10:42pm
What is a good sized plow for the 170-175? AC 2000 monframe or similar? We have tougher soil thru this area.Thanks, Tracy
wade89 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wade89 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 12:33am
I run a 2 bottom 3 point Allis of the generation before the monoframe. Started life as a 3 bottom but it was too much for it when fighting rocks in old pasture ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 4:39am
I wouldn't put anything bigger than a 3 bottom 16" on it, particularly in hilly terrain.  We had a D-19 with a semi mounted 4 bottom, it would pull it, but it was always burying itself in swales, or coming partially out on the crown areas...Wink
As luck would have it, I happen to have a 3 point Allis 16" setup plow, 70 series, I believe, for sale, here in MD.  PM me for details, if you are interested...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 6:18am
A "Monoframe" plow places its front bottom almost in the same place as a fully mounted  3-bottom plows rear bottom is located.  Length is your enemy for how difficult it pulls. 3 x 16's in a mono design would work, but you NEED good rear tires full of fluid (minimum), probably 400-500 lbs on the nose and a working Traction Booster system. Second gear or third gear on the low side.
Edited by DrAllis - 26 Sep 2025 at 6:19am
DanielW View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielW Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 7:56am
Very much dependent on your soil type and what you're plowing down. A 3X16 plow (both our old semi-mount IH 720 and our newer mounted Kverneland/Overums) will bring my 180 to its knees in our soil. First gear all the time. That's in sod on our hills. You'll hear lots of folks talking about pulling 4 furrows with their 50-70 HP tractors. But then you'll see a video of it and they'll be plowing clean stubble on perfectly flat land. Nothing wrong with that, but that doesn't really count as a metric of plow capacity in my opinion: I always felt the measure of how much plow you can pull should be on sod. Because if you still plow regularly, at some point you're likely to want to plow sod (For us, plowing sod/hayfields is the only time you'd ever actually plow: For stubble/row-crops, a heavy offset disc is usually sufficient without plowing). And of course, alfalfa plowing will be tougher than most, as the roots are so thick and extensive.
I'd suggest 3X16 or smaller, depending on your soil type. I'm a big fan of the Scandinavian plows: In our rough & rocky ground, they're the only ones built heavy enough to last, and they pull a lot easier than many other types (the Scandanavian ones seem to be built along the lines of the Oliver plows, with longer, sweeping boards. Way better for turning trash over and easier pulling than, say, the JD plows with their blunt, aggressive board angles). A vari-width is also handy: Our Kverneland and Overum three-furrows are vari-width: The Kverneland is 14" to 18" the Overum is 12" to 16". Very handy to be able to narrow up the width if you find it's pulling too hard, or widen it up if it's pulling easy and you want increased trash clearance and to cover a little more ground.
I will say that our ground is tougher than most. Not necessarily because of the clay content (of which there's very little), but how excessively rocky it is. Not helped by the fact we break up our hay fields so seldom - giving the fields lots of time to develop an extensive and tough root system. We break them up as little as we can because of how rocky it is: Every day of plowing means a week of picking stones, so we go as long as we can without plowing.
Edited by DanielW - 26 Sep 2025 at 8:51am
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 8:09am
We have a 3-16, 70 series on our ser.IV D-17 and it is a great match! Good plow shares and landslide makes a huge difference in how a plow pulls and the job it does.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 6:49pm
Make sure its adjusted right too,, that can change alot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2025 at 8:13pm
Now to find a set of 3-16 Monoframe. Thanks, Tracy
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 3:18am
TracyTN,
This topic reminds me of an earlier post by DrAllis about his analogy of how tractor hp equated to inches of plow width. The 51hp 170/175 = 51”(3-16=48”) plow width??
Here’s an earlier 3pt 3x? AC plow in KY.
https://m.facebook.com/marketplace/item/1461197661755288/?ref=search
Here’s an AC 2000 3-16 plow in IA.
https://m.facebook.com/marketplace/item/1842787992959236/?ref=search
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 7:17am
I don’t believe that plow in ky is a 3pt. Looks like originally a snap coupler.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 9:20am
yeah. Now that I look closer, it’s really gobbled together too.
Edited by AC7060IL - 27 Sep 2025 at 9:21am
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 7:43pm
I have a 3-18 2000 series for my 185, seems to be about right for our conditions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Sep 2025 at 8:44pm
3 x 18's is 54 inches of cut, almost the same as 4 x 14's which is 56 inches of cut.
Post Options Post Options   Thanks (1) Thanks(1)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2025 at 6:58am
Also when looking at model 2000 plow remember they offered a frame extension to add a bottom. If you find a 4bottom with the extension in there you can take out to have 3bottom
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 5:44am
That's a good possibility but keep in mind there may be parts required to make that change that have been lost over the years. I've got a 365 Oliver 3+1. Must have been sold as a 4-bottom because you would need a different brace from the top of the three point to the back bottom to make it work as a 3. Put all new wear parts on it, really looking forward to using it this fall!
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 7:58am
But 18’s also tend to want to cut deeper to do a good job, no? Maybe not these models of Allis? I know I tried to do a HP ratio between tractors years ago and ended up with a 4-18’s Case plow and failed miserably.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 7:59am
After that we ended up with 4-16’s Allis 2000 and pulled it wonderfully!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 8:12am
I've heard the old wives tale about a 14 inch wide bottom needs to plow 7 inches deep. I've done MANY acres with a WD-45 and 3 x 14's and was seldom at that depth. In fact the really tough going 4 to 5 inches deep was the real number. The soil rolled over fine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2025 at 10:00am
Well I don’t know about “wives tales”, other than the 1/2 depth to width is likely a suggestion that most folks probably take too seriously and rigidly.
I also know of my experiences, and encounter some tough going in many places. In tough going I’ve plowed shallower and done a good job turning the ground over. However in heavy sod/ old hayfield plowing I have a hard time turning it over going only 5 inches deep without it forming a huge ribbon and spitting it off the moldboard unturned.
Also know when I talked to my dealer about that 4-18 and how I arrived at that choice he told me I could probably pull 5-16’s the same as 4-18’s. Never tried it because it was obviously too much for the tractor. He explained it was the depth and pitch of the 18 inch bottom was harder going per inch.
Oh well. Lots of information out there and it doesn’t all match up. Your mileage may vary.
Edited by Tbone95 - 29 Sep 2025 at 10:01am
ranger43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ranger43 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 6:32am
We bought a 170 diesel new. 3-14" Oliver Plow for it was perfect. Plowed for years in brutal tight clay.  Loaded rear tires and pie weights. Perfect fit for it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Sep 2025 at 6:42am
Mounted Oliver plow?? or pull-type ??
