170 Questions |
Smitchell ![]() Silver Level ![]() Joined: 16 Nov 2009 Location: Hiddenite, NC Points: 96 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jun 2018 at 1:17pm |
I recently purchased two Allis Chalmers 170 diesels and have a few questions. First off, what oil do I use to service? The manual just says SAE-10W, but haven't had any luck finding just 10w without a 30 or 40 after it. Also what hydraulic oil should I Use? The manual says Allis 322 with an A for ATF, but is that just Automatic Transmission Fluid? Same question about Trans Fluid in tractor, what type? I have a couple of the cylinders that need repacking as well, but thought about just replacing the whole thing. What cylinder measurements will work for exact replacement? Thanks in advance.
soggybottomboy ![]() Silver Level Access ![]() Joined: 20 Feb 2018 Location: Iowa Points: 218 |
A 15w40 diesel engine oil should be used in these tractors,or if it doesn't get below 20 degrees,30 weight diesel engine oil is ok. Transmission and hydraulic needs allis chalmers #821 transmission oil,or any equivalent power fluid.
Allis dave ![]() Orange Level ![]() Joined: 10 May 2012 Location: Northern IN Points: 3073 |
yes, use 15w-40 in the engines. For the transmission and rear end use the Allis hydraulic fluid. You can use another brand if you drain and refill. I have John Deere Hy-Guard in my 185. You can use other generic fluid as well as long as you lookup he specs and it mathces the Allis #821 specs.
Don't forget to change the final drive oil too. It's usually forgotten. Refill with either 80-90 gear oil or hyd fluid.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7517 |
There is no off the shelf cylinder that will fit. Just get your existing cylinders repacked. It's cheaper anyway. A local hydraulic shop can do it if you can't.
