170 pto/bush hog issues |
hickorycreekhoney ![]() Bronze Level ![]() Joined: 08 Jul 2019 Location: 67230 Points: 8 |
![]() ![]() ![]() ![]() ![]() Posted: 08 Jul 2019 at 8:11am |
Info:
6 ft bush hog with lip clutch built in AC 170 tractor with 540 only PTO Issue: I have been mowing the past few days and yesterday the mower would get bogged down while mowing at lowest speed. RPM is at the mark on the guage. When it bogs down, the PTO shaft stops turning as well. The first few times I would disengage the drive mechanism, but leave PTO engaged to get back up to speed and slowly start creeping forward. I finally reached a point where the PTO would not get back up to speed and it seems to spin at a real slow rate, not fast enough to cut anything. I have not tried any other implement on the PTO to see if its an implement issue or a tractor issue, but since the PTO shaft stops spinning when it bogged down, I am assuming its a PTO issue. I am at a loss at this point on what could be the root of the problem. thank you, HCH
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22054 |
FOOT CLUTCH. Make sure you have a minimum of 2 inches freeplay in the clutch pedal.
the clutch appears to be working just fine. I can put the pto in gear and out of gear, as well as the drive transmission and no issues. the pto engage lever seems to work as it should as i can turn on and off the PTO.
WHen the mower is coupled up, the mower spins but with no power, bogs down on short grass. |
BUT, you said the PTO shaft slows way down or even stops turning, or am I reading it wrong ??? If the PTO shaft slows down or stops turning, the foot clutch is slipping on the tractor.
Stan IL&TN ![]() Orange Level ![]() Joined: 13 Sep 2009 Location: Elvis Land Points: 6730 |
If RPM of engine stays constant and the mower PTO slows down it is as the Dr.said, foot clutch is slipping. Check free play and if that is correct you may need a new clutch.
1957 WD45 dad's first AC
yes the pto slows way down or even stops without the foot clutch engaged, even with just grass.
Next question: difficulty of clutch replacement? I am mechanically inclined, just not auto and tractor type stuff.
Hood has to come off and tractor split in two right at the rear of the engine. Must be rolled apart about 3 ft minimum. YOU DID VERIFY THAT THE CLUTCH PEDAL HAS 2 INCHES OF REEPLAY, RIGHT ??
I will double check for freeplay and get back with you. but i feel confident that there was plenty of free play as the clutch works just fine to put the tractor in gear to drive.
If it has zero free-play it will shift just fine and may slip under load.
and by free play you mean loose and sloppy travel when not in use?
Free play is if you stand on the ground and with your hand pull forward on the clutch pedal, (if adjusted correctly) you will move it about 2 inches and it now becomes much harder to move. The point of more difficulty is the throwout bearing coming in contact with the pressure plate fingers. The free play is movement that has no effect on the pressure plate fingers. As a clutch wears, the free play keeps getting less and less and less and less until there isn't any. Then, you have the possibility of clutch slippage because it's like the tractor having the operator with his foot on the pedal all the time.
great explanation. thank you. i will check it out tomorrow evening and report back
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54296 |
You say the bush hog has a (s)lip clutch built in. Try this: Take a paint marker, and paint a line across all members of the slip clutch, from front to back, on the side. Now pop it into gear, just like you were gonna start cutting. Now check the reference line. If it has moved, under no load, slip clutch is way too loose. If it hasn't moved, take it out into the high grass, and repeat the test. If line moves, clutch is too loose, for the load. Most slip clutches have 3 or more tightening bolts, having either springs or belvue washers, that apply the pressure to keep the clutch from slipping, and provide adjustment. Consult your BH manual, for the adjustment, if necessary...
![]() On edit, I see that the shaft is slowing. Nevermind ![]() ![]() Edited by DiyDave - 08 Jul 2019 at 5:50pm |
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
If you disengage the foot clutch when the mower is in wet grass, the mower will slow to a stop. The foot clutch not only disengages the transmission from the engine, but also disengages the PTO from the engine. If you want to stop forward motion to let the mower "catch up", you have to use the power director, slipped to neutral. |
m16ty ![]() Orange Level ![]() Joined: 28 Jan 2011 Location: TN Points: 1476 |
You've got a 170 tractor right? If so, the PTO won't work at all with the foot clutch disengaged. The PTO engagement is a collar on a splined shaft. It either works or it doesn't, it won't "slip", well if it does it will make a whole lot or racket and vibration. Does the forward movement of the tractor also slow down when the bushhog bogs down?
forward movement does not slow down when the pto boggs down. At first when it would bog down, i would use the hand clutch to stop forward movement of the tractor to allow the PTO to catch up before starting forward movement again, but as the day progressed the PTO would no longer catch up to what i thought should be full cutting speed. Even with the PTO on and tractor in neutral with the mower raised in the air.
That is very strange on a 170. Are you sure it’s not your bushhog slip clutch that’s slipping? |
You can't have it both ways. Either the foot clutch is slipping (this is how you initially described it) AND your ground speed is slowing down too, OR there is a slip clutch on the mower and it is slipping (which means the tractor PTO is NOT slowing down). The only way the PTO shaft coming out of the tractor can slow down is if the foot clutch is slipping.
bradley6874 ![]() Orange Level ![]() Joined: 05 Sep 2010 Location: salisbury md Points: 1349 |
Leave the pto off Bushog up drive into some tall grass put a bushog down put the PTO in gear and let the clutch out if the PTO shaft turns it’s probably not the foot clutch it’s the slip clutch On the Bushog if the PTO shaft doesn’t spin it’s the foot clutch end of discussion. That better
Edited by bradley6874 - 09 Jul 2019 at 1:22pm |
Tbone95 ![]() Orange Level Access ![]() ![]() Joined: 31 Aug 2012 Location: Michigan Points: 12230 |
![]() ![]() ![]() Can you try that again? In English? Edited by Tbone95 - 09 Jul 2019 at 12:18pm |
Darn smart phone it has its own language 👍👍
Well, I have a smart phone. It can be challenging to say what you want at times. But it also has periods, commas, the ability to capitalize.....and what auto text complete comes up with Bushong???
![]() ![]() Just pokin' ya'. No offense intended.
You really have to be careful with supposed !!! I almost proposed and It would’ve been bad news
Edited by bradley6874 - 09 Jul 2019 at 4:59pm |
What happens to the engine rpm when the PTO bogs down? If nothing is slipping the engine rpm should also drop.
If the engine rpm stays the same then the foot clutch is slipping OR the mowers slip clutch if it has one is slipping. |
Lynn Marshall ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2415 |
If the foot clutch is slipping that badly, I would think that putting on the brakes would bring it to a complete stop.
If forward motion continues the same and the PTO shaft slows down, you have an internal problem with the PTO connection. Shut the engine off, engage the PTO and put a pipe wrench on the PTO shaft. If you can turn it without the engine turning over, there is something out of wack inside the rear of the tractor.
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
I'm thinking slip clutch on bush hog drive line. Can you video what's happening.
Wink I am a Russian Bot |
TimNearFortWorth ![]() Orange Level ![]() ![]() Joined: 12 Dec 2009 Points: 2014 |
Have you tried hooking it up to something else to check the pto?
Did you figure out what was sloping yet
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1754 |
I had this same problem a couple years ago when I ran my friends Brady green chopper with my 170 gas. It seemed like the pto was slowing down when I went through a thick spot and the chopper wouldn't throw up into the wagon, but I couldn't notice the tractor speed slowing down at all. I haven't ran a green chopper since but I run a small baler just fine. Theoretically it could only be the foot clutch causing the problem.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
