170 gas tractor fuel line?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Topic: 170 gas tractor fuel line?
    Posted: 21 Aug 2011 at 8:08pm
Anybody got a late 170 with sediment bowl outside of side panels? I want to convert mine and need a pic of where the bracket for bowl goes. That bowl under the tank was real genius at work. Thanks Tracy Martin
Larry B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry B Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 8:48pm
mine screws into the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2011 at 9:05pm
Larry, mine has a bowl at the carb also. Manual shows a bracket, part # 0257497-8. Has a screw,self tapping 10 x 1/2.Mine has the bowl under tank, and it is just a problem with cutoff there. I wish I could see a pic of how they were from factory on late 170's. Thanks Tracy Martin
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 8:18am
Any pics of a sediment bowl on late 170 would be appreciated. Thanks Tracy Martin
Edited by Tracy Martin TN - 23 Aug 2011 at 8:19am
Slade (TN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Slade (TN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 2:03pm
They just knew you would be the proud owner of one at one point or another Tracy, no big deal man!!!  lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 5:39pm
I just want to get rid of the leaking compression fittings and line. They will be flare fittings from here forward.I have a late model kit. Just can't figure how the sediment bowl and bracket goes.  Thanks Tracy Martin
Pizzaguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pizzaguy Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2011 at 6:07pm
 My 170 sediment bowl screws into the carb also. Cant post a picture because it is apart to install a carb kit. Anybody know where to get a new fuel shutoff to replace the leaky one under the tank?? I believe it is 1/8" NPT threads and it is a 90 degree elbow. Can't find one anywhere.
1972 170 with Year-A-Round Cab
