170 Gas Shutoff Valve |
Claus
Joined: 09 Dec 2009 Location: Hebron In Points: 1166 |
Topic: 170 Gas Shutoff ValvePosted: 23 Nov 2025 at 7:59pm |
Anyone that has a Gas 170 knows the shutoff valve is in a very unhandy to get to place. I added this Legend 101-520 1/8” ball valve in front of the sediment bowl.
Posted: 23 Nov 2025 at 9:14pm |
I get it. My problem with that design would be a tractor that got used hard and a lot, the weight of the extra pipe thread plumbing will likely loosen up in time. And the Zenith carb is aluminum to boot. I moved my sediment bowl out from under the tank to a place I can easily access it under and behind the left hood rear side panel and then rubber hose to the carb. I could add an in-line filter easily if I wanted to.
Edited by DrAllis - 23 Nov 2025 at 10:29pm |
