170 Front Weight Bracket & Suitcase Weights
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Topic: 170 Front Weight Bracket & Suitcase Weights
    Posted: 24 Dec 2010 at 10:25pm
Is the front weight bracket for the suitcase weights the same on the 170 & 175 only or are they the same from the 170 up to the 185 or 190 Allis? What about the starter weight for the slab type weights and the slab weights themselves? I want to mount a front weight bracket ,preferably to use the suitcase weights with. I would also consider the slab weights,if I can't find a bracket for the suitcase weights. Any help would be appreciated.  Thanks,Rick
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 5:25am
I'm not the expert here but the 170/175 frame in narrower than the 180/185 and takes a different front bracket for suitcase weights. I got one for a friends 180 and its 21 1/2" wide.  Ihe one-nintey only used slab weights on the starter weight. I've never seen a one-ninety with suitcase weights.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 5:47am
Thanks,Calvin...I really didn't know about the 190,just threw that in there. I figured the 170/175 were narrower than the 180/185,because I know the front grills have smaller dimensions on the 170/175 than they have on the 180/185.
Question...does anyone have a front weight bracket for a 170/175 that they would like to sell and,if so,how much? Would much rather have the suitcase weights than the slab weights,if possible. I can get the suitcase weights...all I need is the weight bracket. Need it by this coming spring.  Thanks,Rick
dustinmo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustinmo Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 6:57am
my 190 xt series 3 has a weight bracket and suitcase weights if I go over there today I will measure it and let you know the width
Lester View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lester Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 6:58am
The 170and 175 are about 0ne and half inches narrower but with bushings you can make work,I did.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 7:10am
Thanks,Dustin...I would really appreciate that! Merry Christmas! Rick
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 7:17am
Thanks,Lester! So,in other words,if I use a weight bracket from a 180/185,I just need to use bushings or spacers between the bracket and the frame rails,correct? Well...that gives me three options now. LOL!  Rick
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 8:10am
Rick, is your 170 a front pump or side pump like a D17 IV?
I have a front wrap around for the side mount.   If you install an earlier wrap weight on a later front mount the weight will not mount flat on the front, will work but will be cocked, bottom will be forward more.  The wrap weight for the front pump is notched to fit around the front axle pivot.
As already mentioned, the 180 bracket is wider than the 170, spacers will do the trick.
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 8:21am
Allis Chalmers 170 and 175 frame width was not the same. The 175's were approx. 1/2" wider. I'm not sure about all 175's. It might be just the models after AC went to the crankshaft driven hyd. pump. (s/n 2035 and up)  Front mount suitcase Wts. were offered on both the 170 & 175.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 8:27am
I'm sure I've got a sales brochure of the Landhandler 190's with suitcase weights. I'll look, not that it matters. I should scan some brochurse and post them.
Wink
I am a Russian Bot
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 25 Dec 2010 at 8:54am
Joe, You've got mail!! Merry Christmas!!  Rick
