|  | This site is not affiliated with AGCO Inc., Duluth GA., Allis-Chalmers Co., Milwaukee, WI., or any surviving or related corporate entity. All trademarks remain the property of their respective owners. All information presented herein should be considered the result of an un-moderated public forum with no responsibility for its accuracy or usability assumed by the users and sponsors of this site or any corporate entity. | |||||
| 170 Flywheel |
| Post Reply   |
| KurtDE   Bronze Level     Joined: 19 Sep 2009 Location: Hilton New York Points: 83 |  Post Options  Thanks(0)  Quote  Reply  Topic: 170 Flywheel Posted: 15 Feb 2010 at 6:32pm |
   I was looking at the flywheel on my 170g and it is worn severely. I know that the depth of the surfaces is supposed to be 1.437" and i'm sure this will be greater than that after it is resurfaced. My question is the outer edge cut down so that the surfaces are back to the original specs? and how does this affect the clutch adjustment?
| Hurst   Orange Level   Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Feb 2010 at 6:41pm |
   A good clutch shop or machine shop that's done flywheels before should know how to do this.  You cut the lip where the pressure plate bolts down the same amount you take off the clutch surface of the flywheel.  Normal operating procedure for flywheels.  If it's not warped and hasn't been resurfaced a billion times, it should be good for resurfacing.  Check the yellow pages or ask around the truck repair shops to find a good clutch shop.  Way less money and if you ask around for a good shop, definitely better materials than you can get in the aftermarket and OEM kits.  Also, they can tweak the set up slightly to better suit your situation if it needs to be. Hurst | |
     1979 Allis Chalmers 7000
 5800 Hours | |
| Hurst   Orange Level   Joined: 11 Sep 2009 Location: Midway, Ky Points: 1218 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Feb 2010 at 6:44pm |
   I should have said, you may want to take a copy of the depth spec (1.437 inches) with you in case the flywheel is really worn down so the flywheel can be machined back to spec.  Also, if done correctly, there will be no effect in clutch adjustment, you'll just have to adjust it back out. Hurst | |
 5800 Hours | |
| norm [ind]   Orange Level   Joined: 16 Sep 2009 Location: BOURBON,IN. Points: 667 |  Post Options  Thanks(0) ![Quote norm [ind] Quote norm [ind]](forum_images/quote.png) Quote  Reply  Posted: 15 Feb 2010 at 7:09pm |
| was a button cluch used or a woven one used a botton clutch will wear a groove in it    you did not say which  a button c lutch is no good for a loader tractor | |
| KurtDE   Bronze Level     Joined: 19 Sep 2009 Location: Hilton New York Points: 83 |  Post Options  Thanks(0)  Quote  Reply  Posted: 15 Feb 2010 at 7:30pm |
   It had a button clutch in it. I thought the button was a heavy duty clutch?
| Post Reply   | |
| Tweet |
| Forum Jump | Forum Permissions  You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum |
