170 Flywheel
KurtDE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Topic: 170 Flywheel
    Posted: 15 Feb 2010 at 6:32pm
I was looking at the flywheel on my 170g and it is worn severely. I know that the depth of the surfaces is supposed to be 1.437" and i'm sure this will be greater than that after it is resurfaced. My question is the outer edge cut down so that the surfaces are back to the original specs? and how does this affect the clutch adjustment?
Hurst View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 6:41pm
A good clutch shop or machine shop that's done flywheels before should know how to do this.  You cut the lip where the pressure plate bolts down the same amount you take off the clutch surface of the flywheel.  Normal operating procedure for flywheels.  If it's not warped and hasn't been resurfaced a billion times, it should be good for resurfacing.  Check the yellow pages or ask around the truck repair shops to find a good clutch shop.  Way less money and if you ask around for a good shop, definitely better materials than you can get in the aftermarket and OEM kits.  Also, they can tweak the set up slightly to better suit your situation if it needs to be.
Hurst
1979 Allis Chalmers 7000
5800 Hours
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hurst Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 6:44pm
I should have said, you may want to take a copy of the depth spec (1.437 inches) with you in case the flywheel is really worn down so the flywheel can be machined back to spec.  Also, if done correctly, there will be no effect in clutch adjustment, you'll just have to adjust it back out.
Hurst
5800 Hours
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 7:09pm
  was a button cluch used or a woven one used  a botton clutch will wear a groove in it
   you did not say which  a button c lutch is no good for a loader tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote KurtDE Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2010 at 7:30pm
It had a button clutch in it. I thought the button was a heavy duty clutch?
This page was generated in 0.060 seconds.
